Priming for Acrylic Paints
    September 2004
Posted by jowdawg on Monday, November 29, 2004 9:32 AM
Is it necessary to prime for acrylic paints? I have seen posts that say you do not need to prime. I prime because it gives me a good base from which to do finish work, ie putty imperfections, or sand high spots, prior to the color coats.
    July 2003
Posted by madmike on Monday, November 29, 2004 4:14 PM
I personally believe that it is for all the reasons you have stated. I more often than not use Tamiya primer, either fine white or the normal grey primer. Being lacquer based, it gives a rock solid foundation for any subsequent acrylic paint applied.
As I tend to build a lot of older, more esoteric kits, priming is the only way I can ensure a uniform surface that blends filler and plastic together.
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
