Thinner for oil paint weathering???
    February 2004
Posted by abutt2 on Friday, December 3, 2004 10:30 AM
Trying to find an article in my back issues regarding the thinner used for oil paint weathering. The article spoke of several thinners. One that I'm using is lighter fluid. Now with the no smoking trend...try and find lighter fluid. Another thinner mentioned was Naptha. New store opened near me (Tractor Supply) has every knid of thinner you could imagine, including Naptha. Just trying to find the article to confirm my thinking. Paint use was like a Grumbacher Burnt Umber tube oil paint. Looks great on a tank desert scheme. Any help on the article?
BudBig Smile [:D]
Posted by Anonymous on Friday, December 3, 2004 11:27 AM
I'm just finishing my ZIS-5 truck with an oil paint weathering. I'm fading the Russian Armor Green with a olive green mix. I'm using a combination of about 10 parts mineral spirits to 1 part Boiled Linseed oil. Some folks use a 50/50 mix, but I see no reason to use that much Linseed oil, it just takes too long to dry and makes the model very glossy. Any ordinary paint thinner from the hardware store will do. The Linseed oil slows down the drying time and makes it easier to move the oil paint around. You can either brush or spray the model with the thinner mix, then apply small spots of paint and blend them in. Make sure you seal the model's base-coat with a clear coat first. Let dry for several days before top-coating to get rid of any glossy areas.
Posted by rjkplasticmod on Friday, December 3, 2004 1:36 PM
Mineral spirits or Turpentine will work just fine. From my experience, go real easy on Linseed oil. I rarely use it anymore.
Regards, Rick
    August 2004
Posted by Tankmaster7 on Friday, December 3, 2004 7:34 PM
I use mineral spirits, it works fine.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    January 2003
Posted by plasticmod992 on Saturday, December 4, 2004 3:58 PM
I use regular *orderless mineral spirits as well for oil washes. Mineral spirits is not as agressive as say Naptha and lighterfluid and others (less stinky too!). It blends my MM enamels great and I have gotten great results. As others have mentioned, make sure to put a clear coat on to protect the surface prior to application. Future floor polish makes a great clear glossy protective layer for subsequent weathering with oils. Happy modeling!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
    December 2003
Posted by cbreeze on Saturday, December 4, 2004 3:58 PM
I have been using lighter fluid and it works great. I found it readily avalilable at my local drug store.
Posted by Anonymous on Sunday, December 5, 2004 5:54 PM
I use turpenoid. It's a low odor (not non-toxic!) thinner available with the oil paints.
Dan
