Gravity Fed airbrush question
    August 2003
Posted by Bwog on Monday, December 6, 2004 1:11 PM
Dear FSM forum,
I recently received Badger's 360 airbrush with the gravity fed option. Is there a cup or container to hold paint? There is a funnel device on top of the airbrush but shouldn't there be a accessory piece to fit into this? I checked out Badger's webpage and didn't see any thing listed?
Surly i don't just poor paint into it, there must be a reservoir of some sort for gravity fed airbushes...?
Thanks?
Bwog
    April 2004
Posted by pmm736 on Monday, December 6, 2004 1:51 PM
Thats the color cup, which many have complained is too small to be of much use.
    January 2004
Posted by MusicCity on Monday, December 6, 2004 2:41 PM
Yep, that's the color cup. You can also rotate it downwards and use a bottle in siphon feed mode.
Posted by Anonymous on Monday, December 6, 2004 4:42 PM
That small colour cup is primarily for using small amounts of paint for very fine spray jobs or light weathering effects you rotate it and use a siphon feed bottle if you are applying base coats or spraying large areas!
Posted by Delbert on Monday, December 6, 2004 7:24 PM
I have the 360 and I use the gravity feed option when I only need to spray a small part or touch something up and it isn't worth hooking up the siphon feed.. its also very handy for cleaning.. after using the siphon feed I turn it up and use it to hold the thinner I spray thru it for cleaning....... all in all I love the airbrush and is what i use for most of my airbrushing now..
Posted by Anonymous on Monday, December 6, 2004 9:20 PM
you can prob mod a fast blast to work there
Posted by MikeV on Monday, December 6, 2004 9:49 PM
All of the standard plastic and glass jars will fit the 360.
Even the Paasche jars fit it.
