Sounds to me as though you have the unit with the holding tank underneath the motor unit, if so it should have a dial and a guage, on the watertrap for adjusting the air pressure, if so set it at 20 psi without depressing the trigger, it will drop down to around 15 psi when the trigger is depressed.
I taught airbrushing to beginers, using the Passche VL and acrylic paint [only for ease of cleaning], using a Sparmax Compressor that was set at 15 psi.
