Airbrushing... Basic Info Needed/Verified
Posted by Anonymous on Saturday, May 17, 2003 3:05 AM
Hello Everybody,
I purchased a Central Pneumatics Air Compressor and Heavy Duty Dual Action Airbrush from Airbrush City and as far as I can say, I love it.... Its easy to handle and everything.....
Now..Heres what Im not sure.... I've read somewhere that to thin MM Enamels.... For Gloss, 3 parts paint to 1 part thinner, for Flat, 2 parts paint to 1 part thinner????
What does everybody here uses, and what PSI do you run whenther its Gloss or Flat???
To help getting the answers, Im working on F-14A and F-14D Tomcats, 7 from Revell-Monogram, 1 from Academy, and 1 from Fujimi... All are 1/48 scale.
Thanks!
Posted by Anonymous on Saturday, May 17, 2003 3:07 AM
Instead of, "What does everybody here use?" I meant to ask, "What ratio does everybody here stick to, for both Gloss and Flat Model Masters Enamels?"
Thanks again
Posted by midnightprowler on Saturday, May 17, 2003 6:07 AM
I thin my paaints to the consistency of whole milk, and run my pressure 15-30 psi. Hope this helps.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Saturday, May 17, 2003 11:13 AM
I don't measure exactly, but generally I'd say my thinner/paint mix is anywhere from 30/70 all the way to 70/30, depending on the paint. The most common would be 30/70 to 50/50. I generally use the same method as midnimghtprowler. After practice, you'll learn to 'recognize' the right consistency. I shoot a small test spot against the side of my paintbooth and that usually tells me if it's too thin or too thick.
M.
    January 2003
Posted by shermanfreak on Saturday, May 17, 2003 1:57 PM
Can't add much to what both Lee and Murray have already said, other than that I totally agree with them.
Posted by Anonymous on Saturday, May 17, 2003 3:36 PM
If you use lacquer paints, the ratio gets to be critical, otherwise you can get spider webs or what looks to be cotton candy.
I usually thin my paints enamel/acrylic so that they run freely down the side of the jar, but coat it with a solid color as they do. Watch the humidity, if the paint is thinned too much (but still covers decently) it will take forever to dry, especially in a cool environment.
    February 2016
Posted by eaglecentral on Sunday, May 18, 2003 12:33 AM
MM enamels, flat or gloss, use MM Airbrush thinner 50:50 for first coats and general work. Make it about 60:40 for 2nd coats and fine detailing. I use the Mk I Mod 0 eyeball to measure. I keep the pressure at 20psi and adjust it up until I get a good fine spray pattern. I rarely have to go past 25psi. This works for a Badger 150 and for a Paasche H. My Aztec 470 needs more pressure so I usually start around 25psi and work up. I use MM enamels only.
Tom
