Stripping Future
    August 2004
Stripping Future
Posted by Tankmaster7 on Friday, December 10, 2004 6:36 PM
How? (The underlying coat is enamel) Thanks, Tank
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    January 2004
Posted by MusicCity on Friday, December 10, 2004 7:07 PM
Windex or alcohol. Windex works best.
    August 2004
Posted by Tankmaster7 on Friday, December 10, 2004 7:59 PM
Just wipe it with a bounty or something? or do i need to soak it? (the entire model?)
    July 2004
Posted by tho9900 on Friday, December 10, 2004 8:59 PM
just wipe it off...
If you sprayed with enamel you could just spray the windex directly on the model and let it sit for a sec then wipe it off... I would be wary of doing that with acrylics because it might strip them too...
With acrylics definitely spray on the towel first...
    January 2004
Posted by MusicCity on Friday, December 10, 2004 9:03 PM
You shouldn't need to let it soak. Windex will usually wipe out Future IMMEDIATELY. As Tom mentioned, spray it on a towel and wipe it off. I'd recommend using something lint free.
    August 2004
Posted by Tankmaster7 on Saturday, December 11, 2004 10:48 AM
ok then. that doesn't sound too hard.
Posted by sh00ter on Monday, December 13, 2004 8:53 AM
It's the ammonia in the Windex that does the trick. No soaking required.
"where plastic can be a four-letter word..."
    January 2004
Posted by MusicCity on Monday, December 13, 2004 10:39 AM
QUOTE: It's the ammonia in the Windex that does the trick. No soaking required.
Yep, but using plain old ammonia is rough on the nose which is why I recommended Windex instead. You are absolutely right though, if you can stand the smell plain anhydrous ammonia will dissolve it in a hurry.
Posted by Anonymous on Wednesday, January 26, 2005 3:24 PM
Good to know, as I plan on playing with weathering using an enamel base coat with acrylics to test my masking/other abilities. I'll paint it WHATEVER using the acrylics, then top it with the Future (testing my weathering/whatever you call it along the way). Once done, Windex that sucker and start over. Sound about right?...
