Need some help with my airbrush
Posted by Anonymous on Saturday, December 11, 2004 4:31 PM
I tried it today for the first time in a little while, and it's not working. i cleaned it out extremely thurouly, still nothing. it doesn't even spray water. any suggestions at what the problem is?
    July 2004
Posted by tho9900 on Saturday, December 11, 2004 6:04 PM
any air coming out? if not is it blowing out around the trigger or anywhere else?
    August 2004
Posted by Tankmaster7 on Saturday, December 11, 2004 6:15 PM
what kind of airbrush is it? it isn't gasp, the 155 is it?
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by MikeV on Saturday, December 11, 2004 6:25 PM
Is it an Aztek? Laugh [(-D]Mischief [:-,]
Posted by rjkplasticmod on Saturday, December 11, 2004 6:30 PM
Is the compressor plugged in ?
Rick
    January 2004
Posted by MusicCity on Saturday, December 11, 2004 6:45 PM
Something is obviously blocked, either the air path or the paint path.
Make sure you have air, if not disconnect the hose from the airbrush and see if you have air there. If not track backwards and find out why you don't. If you have air at the hose end but not when you push the trigger, make sure the trigger is properly seated on the air valve and make sure you can feel the air valve moving when you press the trigger.
If you have air but no paint, make sure the vent hole in the cap is open, the tube and cap head are open, etc.
Posted by Anonymous on Saturday, December 11, 2004 9:33 PM
none of those things, i made sure my compressor is plugged in, the air hose is working, air's coming out really slowly, water doesn't spray, and it leaks to the back a little bit.
I already cleaned out 2 months of gunk (approx 3 grams of dried paint) and it still doesn't spray. I've read the badger manual again, and i tried everything cept the teflon bearing and it's still not working. paint has a clear path.
Posted by Anonymous on Saturday, December 11, 2004 10:10 PM
have you tried a dunk test to look for leaks ?
Posted by MikeV on Saturday, December 11, 2004 10:58 PM
Ryan,
What did you do when you cleaned it thoroughly as you said?
You didn't run something down the needle tube and damage the needle bearing did you?
Posted by Anonymous on Saturday, December 11, 2004 11:58 PM
mike, no and i just used those pipe cleaners between wher the nozzle and the paint goes, that path, and i got out a ton of gunk (not teflon)
I looked at the rear of the body inside, and there's some paint in there, in the non-importnat parts. any suggestions?
Posted by MikeV on Sunday, December 12, 2004 12:43 AM
Ryan,
What about the small holes in the head that the air travels through?
Are they clear?
Posted by Anonymous on Sunday, December 12, 2004 11:30 AM
yep
Posted by MikeV on Sunday, December 12, 2004 11:33 AM
Ryan,
I suggest you send an email to Ken Schlotfeldt at Badger and tell him what it is doing. He will take care of you.
kenbadger@aol.com
    January 2004
Posted by MusicCity on Sunday, December 12, 2004 11:37 AM
Air is coming out very slowly? Did you take the hose off the airbrush and check for good flow at that point? If you have good airflow at the hose I think it may be a bad air valve. Unscrew the airvalve from the airbrush and screw it onto the hose. Push the pin at the top and see if there is as much air flow.
Posted by MikeV on Sunday, December 12, 2004 11:55 AM
Good points Scott.
Maybe he got paint into the airvalve?
Posted by Anonymous on Sunday, December 12, 2004 12:09 PM
no paint in airvalve, thanks guys
no problem with air, it's paint.
    August 2004
Posted by Tankmaster7 on Sunday, December 12, 2004 2:51 PM
obviously you've thinned the paint properly. hmmmm, if all else fails, send the thing to badger. they should repair it for you.
    August 2004
Posted by Tankmaster7 on Sunday, December 12, 2004 2:53 PM
odd. i had the same problem with my aztek though. the nozzles was completely clogged... maybe the nozzles isn't screwed in good on the badger? if air's coming out slowly, is your regulator set to too low a setting?
Posted by Anonymous on Sunday, December 12, 2004 3:23 PM
the air is fine, it's the paint flow. the air works at all ranges, from 5> psi to 40. although, when i drain the hose after i turn off my compressor (Always a good idea) it takes longer than normal.
    August 2004
Posted by Tankmaster7 on Sunday, December 12, 2004 3:48 PM
odd. very odd indeed. i think you should send it back to badger. they'll fix you up, i think.
Posted by Anonymous on Sunday, December 12, 2004 4:26 PM
at least its not as bad as the aztek problem
