microscale industries' micro flat finish
Posted by Anonymous on Wednesday, December 15, 2004 1:23 AM
hey all, new to the forum. got a quick question.
I'm using the micro flat clear finish from microscale and so far it's not actually flat. brushed it on. i don't think it's as glossy as the micro gloss underneath it but flat it just ain't. i can actually see some reflections in it. admittedly this layer is only half a day old at this point. is it going to turn flat after a while or should i just get another finish and go over it?
any help would be good. i don't think panzer crews waxed and polished their tanks.
Posted by rjkplasticmod on Wednesday, December 15, 2004 9:21 AM
Welcome to the Forum Sign - Welcome [#welcome]. I find Polly Scale acrylic flat to be the best available if you want a real flat finish.
Regards, Rick
Posted by Anonymous on Wednesday, December 15, 2004 1:47 PM
I tried thinning mine first with just a touch of water and it did flatten down nice enough.
Posted by Anonymous on Wednesday, December 15, 2004 2:30 PM
i've got testors dull cote in a spray can and model masterflat clear lacquer finish. any opinions on either of these? i'd brush the MM stuff on or spray with the testors can.
Posted by ABARNE on Wednesday, December 15, 2004 2:35 PM
I had the same issue with that product. If your LHS doesn't stock Polly Scale flat, you can mix Tamiya X-21 Flat Base with Future in about a 3:1 or 4:1 ratio to make a really nice finish. Presumably, you could mix Flat Base with the Microflat as well, although you would need to experimanet to determine a desirable mix ratio.
    August 2004
Posted by Tankmaster7 on Wednesday, December 15, 2004 3:03 PM
careful with the lacquers. especially if brush painting! they can eat right through your paint!
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Wednesday, December 15, 2004 3:17 PM
would they eat through the clear finish that's on there already? it's already base coat+gloss coat+weathering+"flat coat".
    August 2004
Posted by Tankmaster7 on Wednesday, December 15, 2004 3:42 PM
it dpends. what kind of clear coat was it? acryl? enamle? wither way i would be very careful. give it 48 hrs to cure. at least
Posted by Anonymous on Wednesday, December 15, 2004 3:51 PM
You could try Floquil Dead Flat, it gives a very nice flat finish.
