QUOTE: Originally posted by austkdang
G'day Guys,
I've been reading and getting informations and tips from this forum. Thanks, everyone.
Now to alclad P/A, I've under-coted the P-38 with the gloss black. I've tried both auto-paint and Tamiya TS-14 and found that it is hard not to get the overspray (which will dull the surface). At the end I managed to get it done.
When I applied the P/A, it looked as if I only spray a cote of clear lacquer with very little glitter of metal. I then tried to put some more cotes on ( about 10 min apart) it looked more and more metal. Until one and a half bottle of alclad later ( I still feel that I need more cote), It looked like a non-metalised silvery paint. So I left it for 24 hours. Everythings still the same. The surface is shiny and glossy enough, but the color look real plain. Nowhere near the sample shown on Alclad page.
I've just return to modelling recently (after about 20 years) so I assumed that its something that I did wrong.
Thanks in advance.
Pingy is right mostly, the Alclad does need gloss black undercoat.
I think you need to either shake the bottle ALOT more, or check your spray pressure, because it shouldn't take a bottle and a half to coat a plane.
When I used my Alclad last, half a bottle was all I used, and that was with 2 coats, and total coverage of the entire model.
After shaking the bottle, you have to move pretty quickly to transfer the Alclad to your airbrush, the pigments tend to settle VERY quickly too the bottom, and the occasional stir with a toothpick while spraying will keep everything nice and consistent.
As for the acrylics, they work great when you add retarder to the mix.
I have a special bottle prepared for my acrylics, they are all I use 99% of the time.
It has 50% Iso Alcohol, 50% Distilled water, and 10 drops of retarder, in a 50ml bottle.
Works fine.
Hope this helps
Cheers
Sean
