Did a modification on my Badger Million-Air compressor
Posted by MikeV on Tuesday, December 21, 2004 9:48 PM
These silent compressors do not come with any cooling system so I got creative and made this for mine today.
I cut a piece of a sheet metal box lid off with a sabre saw to use as a mount.
I drilled a hole through one end of the lid and mounted it into the compressor case under the bolt that holds the handle on top of the case. I then drilled two holes in the end that stuck out of the case and mounted a 120mm computer fan to it. I then soldered two wires to the fan, put connectors on the other end of the wire and connected it to the wiring inside of the pressure shutoff switch so that whenever the compressor is plugged in the fan is on all of the time.
It came out pretty good and hopefully will make this compressor last even longer as it will run cooler.
Posted by Anonymous on Tuesday, December 21, 2004 9:50 PM
mike, how'd you power the fan?
Posted by MikeV on Tuesday, December 21, 2004 9:52 PM
Did you read what I posted above? Laugh [(-D]
I wired the fan to the hot side of the power cord in the pressure switch box. Wink [;)]
    July 2004
Posted by tho9900 on Tuesday, December 21, 2004 10:04 PM
that's where the squirrel cage, and the three hired hamsters come in... Wink [;)]
    August 2004
Posted by Tankmaster7 on Tuesday, December 21, 2004 10:08 PM
lol. i think hamsters work for free though.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Tuesday, December 21, 2004 11:08 PM
food costs
Posted by Anonymous on Wednesday, December 22, 2004 12:34 AM
just feed them table scraps
    January 2003
Posted by plasticmod992 on Wednesday, December 22, 2004 12:50 AM
Thats a neat idea Mike, you should contact Badger with the idea...I see potential dollar signs with that one$$$
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by MikeV on Wednesday, December 22, 2004 1:13 AM
Thanks Greg. Big Smile [:D]
Posted by maddafinga on Wednesday, December 22, 2004 8:47 AM
That's pretty cool Mike. If I tried something like that, I'd have no idea where to solder stuff to make sure it got power. With my luck, I'd probably ruin not only the fan, but also the compressor.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Wednesday, December 22, 2004 10:58 AM
actually josh, soldering and stuff isnt very difficult, its gets very easy after learning a few things on how to deal with the new material. a 60 watt and above iron helps too
Posted by MikeV on Wednesday, December 22, 2004 11:03 AM
With A/C it does not matter, either of the two leads on the fan can be positive or negative. Wink [;)] The green lead is hot and the black lead is ground in the compressor wiring.
There is also a white lead but it is neutral.
I have too much of my dad in me as he could make practically anything. Big Smile [:D]
    May 2003
Posted by styrene on Wednesday, December 22, 2004 12:00 PM
Uhh, Mike?
Stupid question time....
Is the fan pulling air or blowing air? The difference between the two is almost a factor of 10. Unducted, the exhaust capability is only about 1/10 that of the positive pressure (blowing) side. Just wondering....
Merry Christmas!
Gip
Posted by MikeV on Wednesday, December 22, 2004 12:24 PM
Good question Gip and I should have mentioned that. Big Smile [:D]
The fan is drawing air from the room and blowing it towards the head of the compressor motor. Wink [;)]
    May 2003
Posted by styrene on Wednesday, December 22, 2004 12:25 PM
Good!
Gip
Posted by MikeV on Wednesday, December 22, 2004 12:29 PM
Gip,
I didn't just fall off a pumpkin wagon you know. Tongue [:P] Laugh [(-D]
How have you been Gip? I sent you an email a while back and never heard from you. Was it something I said? Confused [%-)]Laugh [(-D]
Posted by Anonymous on Wednesday, December 22, 2004 12:39 PM
When I read the title, I had images of a Tim "The Toolman" Taylor modification. Glad it wasn't and that it still works Propeller [8-]
Posted by Anonymous on Wednesday, December 22, 2004 1:14 PM
Mike, if badger accepts... you're oging to get a lifetime supply of badgers... not that you need them though Laugh [(-D]
Posted by MikeV on Wednesday, December 22, 2004 1:50 PM
I doubt there is anything I can come up with that they haven't thought of already. Wink [;)]
