If I may add, I have an Iwata HP-BCS (Eclipse, bottle feed), and have serious problems spraying acrylics and lacquers. What I get, no matter what the thinning ratio and air pressure, is a very pronounced orange peel effect. In fact with the Tamiya acrylics, I get a dry powder effect if the spraying distance is more than 1 1/2 inch! I have an old dual-action airbrush with a 0.7mm needle and it sprays Tamiya acrylics without a problem. the main difference is the paint flow. For thick paints on broad surfaces, you NEED a high flow airbrush. The eclipse, with its specific 0.5mm needle which can also do hair-lines, is not appropriate. It can work on details, however, by reducing the pressure and spraying very close from the subject.
The eclipse, however, works very well with testors enamels. I think the problem with the eclipse, ironically, is that the atomization is too fine, which tends to dry the paint as it is sprayed.
Most of the spraying I do is at around 20 PSI, sometimes 15 for detail work. I use an Iwata Smart-Jet compressor, very nice and silent little device (once the "bleeder" pressure regulator was replaced with a true regulator!)
Oh, and no, my eclipse works as it should, I have replaced the needle and nozzle already, and the ambient conditions are suitable for spraying (70F, 30% humidity when I tested).
