Tamiya acrylic/ laquer thinner test
    January 2003
Posted by plasticmod992 on Monday, December 27, 2004 3:53 AM
After reading the various posts on the subject at Hyperscale, having tried Tamiya's house thinner, 91% and 70% alcohol, distilled water, and Windex with mixed results- I tried modeler, Tony Bell's method of thining Tamiya Acrylic with laquer thinner. In a word, WOW! Not only did it work, I was able to sustain the finest, softest atomized fine lines to date using this paint. In testing Tony Bell's method, I prepaired the paint by stiring it in-bottle slowly and thouroghly. Next, I dispensed the paint into a empty fim canister adding the laquer thinner at a ratio of roughly 1:1 and stirred the mix thouroughly. When stirring, I noticed that the laquer thinner blended the paint emmediately with no separation of of the pigment or vehicle, not did it gum-up, or dry-up in the film canister. I put the mix to the test, loading it into my Iwata HP-C airbrush with it's tiny .3mm nozzle/needle- surely if sprayed through this airbrush, I would be sold. I dropped the air pressure to approx. 12 psi and began to spray tiny fine lines, to my amazement that were extremely well atomized-compairable to MM enamels! Still suspicious, I waited to see if the mix would begin to clog, spit, separate, gum-up, or whatever else. Shockingly yet, it never did, it stayed thouroughly mixed as I continued to spray for 5-7 minutes. I then set the airbrush down with the paint sitting in the airbrush to see if it would dry up, or clog the tip. Nope!, I pulled back on the trigger and I resummed spraying!
After spraying, I checked the integrity of the paint film. I was surprised that the paint (Dark Grey, XF-24) covered very well over dark colors (flat black, dark green, gunship grey, etc.) and it was tough and dried fast. The paint film had a smooth, slightly satin appearance with no suspected graininess, dry spots, fish eyes or orange peel. I then rolled up my sleaves and grabbed the masking tape for the final test. After 10 minutes or so after spraying, I layed regular and blue painters masking tapes over the painted areas, burnishing it down with my fingers. Abruptly and quickly, I pulled the tape from the painted area and......nothing came off!, cool! Now excited and grining from ear to ear, I finished up by cleaning my airbrush with the laquer thinner as normal. I am shocked and amazed at this test using Tony's method....why didn't I try this 10 years ago???!! It works guys...man does it work. The only con, and It's a BIG one: this method negates the "clean-up with water, no harsh chemicals" notion of acrylics. I don't know if others have tried this before with any sucess, but man...do I have a new appreciation for this paint. Doing more tests...I'll report back later.
Comments and thoughts on this are encouraged, what do you guys (and gals) think?
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by maddafinga on Monday, December 27, 2004 1:24 PM
Hmm, interesting. I'm anxious to hear more about this Greg.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Monday, December 27, 2004 3:56 PM
Tamiya Acrylics... with the x's before the numbers??? Tamiya acrylics??? really??? Laq. thinner *big smile*
Dude I am about to ab my big hog I been putting blood sweat and tears into and worrying about the acrylic overall sea blue. I am not particully found of acrylics, but my wifes sensitive body cant handle to many of the Laq fumes. When cleaning that test after words.. did you use any more or less Laq. to get the brush clean. I tend to over due it in my cleaning and this is intersting to me as imho Tamiya makes a dead on seablue straight outta the bottle.
Anything else come outta that test?
Jeff
    December 2003
Posted by 9x19mm on Tuesday, January 11, 2005 2:18 PM
I just tried this method for the first time today and I must say Im exceedingly happy with the results. I to now have a new found appreciation for Tamiya paint and will be using it as much as possible. I am just thrilled with the results.
Posted by waikong on Tuesday, January 11, 2005 4:02 PM
Like you said, the big drawback is the fumes, the main reason I switched to Acrylic. I still use Alclad II, but everything else is Acryl. Spraying enamel in general I find is much easier and finer than Acryl, do you find that this combo is better or equvalent to enamel? Because if I'm going to put up with the fumes anyway, might as well go with what works better. Thanks for the input.
    August 2004
Posted by Tankmaster7 on Tuesday, January 11, 2005 4:58 PM
Wow, that's really cool. I have to rry that. I do usually work with enamels though.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    May 2003
Posted by styrene on Tuesday, January 11, 2005 9:10 PM
Out of curiosity, which brand of lacquer thinner did you use, who is the manufacturer, and is there a part or catalog number associated with the product?
Thanks
Gip Winecoff
Posted by MikeV on Tuesday, January 11, 2005 9:27 PM
Doesn't using lacquer thinner for acrylics kind of defeat the purpose of buying acrylics in the first place? Confused [%-)]
    December 2003
Posted by 9x19mm on Thursday, January 13, 2005 2:41 PM
Styrene i used klean strip lacquer thinner part # Q17014 purchased at my local walmart and it is proudly made in the good ol USA.
Mikev of course thinning with lacquer does defeat the purpose of acrylic but as with most modelers I seem to over engineer things. But on a more usefull note I have had random luck getting a finish that I like with acrylic from either MM or Tamiya I know this is my lack of skill rather then the paint or my AB (I have only but 9 mos of AB experience). So to make a long story short I have a bunch of acrylic paint that would be unused and wasted. The ends justify the means I suppose and if I can use up the paint and still get a good finish then Im happy.
Posted by Anonymous on Friday, January 14, 2005 4:02 PM
9X19mm, Tamiya Acrylic thinned correctly with thier own thinner (X20A) will give you one of the best finishes available of any model paints. Have you tried spraying with Tamiya's own thinner? Thumbs Up [tup]
Cheers....Snowy
Posted by Anonymous on Friday, January 14, 2005 5:31 PM
I tried it yesterday and I am stunned, speechless as to the finish I got on my 1/32 corsair. Having also used the tamiya thinner (this for snowy), I say I have at least half again better finish with Lacq. thinner. I used #w5700 for the thinner Styrene. I thinned Tamiya Acrylic XF-17 Sea Blue cut 50/50 with the afore mentioned Lacq. Thinner and sprayed it at 10-12 psi with my 360. Follow Plasticmod's advice very closely because the careful stirring is very important.
Clean up was cool too as I found I needed very very little thinner to clean it with (including backflushing), so while the usual stinky fumes where there it was not as bad as usual. STill experience minor tip dry but the crust was uniform and easy to scrape off.
    December 2003
Posted by 9x19mm on Friday, January 14, 2005 10:03 PM
Snowy yes I have tried and only used Tamiya thinner until so recently...
Woodbeck3 Im glad you had the same reults and feelings as I had, I was begining to wonder if it was just me.
Posted by Anonymous on Friday, January 14, 2005 11:22 PM
Well the results you guys are posting sound really promising, I wonder would it be possible to still clean the airbrush with alcohol and Windex? At least that would minimise the use of Lacquer thinner. Funny thing is I noticed for the first time at the LHS they had 250ml jugs of "Tamiya Lacquer Thinner" (Never seen this before) which I thought odd as the only paints they have which would require thinning are thier acrylic range and thier enamel range, both of which have thier own special thinners. Maybe they have cottoned on to the improved results people are reporting by using Lacquer thinner with thier paint and are cashing in. On another note people, should be aware that unless thier airbrush has packing seals which are impervious to lacquer thinner then they shouldn't try this or they will damage the seals. For example, I don't think my HP-CS is set up with seals to handle Lacquer but I believe my HP-CR Revolution is OK to go as it has teflon seals from the factory (Someone please correct me if I'm wrong). Just thought it might be usefull to mention this as some people may ruin thier airbrush by trying this out. Smile [:)]
Cheers...Snowy
    December 2003
Posted by 9x19mm on Saturday, January 15, 2005 1:52 PM
Snowy I just finished painting and I verified that clean up is easily done with alcohol and windex. Hope this is of use.
    January 2003
Posted by plasticmod992 on Sunday, January 16, 2005 3:50 AM
Snowy, I inquired about the seals and so forth for my Iwatas too, and what I found out after talking to a Coast Airbrush representative was that the HP-C and CS are fine for spraying Laquers. The caution they raised was that if you want to use "Hot" automotive-type urathanes a teflon needle bearings are a must. FYI, I have used Laquers with no problems at all in all on my Iwatas. Rest assured my good man!
Posted by Anonymous on Sunday, January 16, 2005 3:37 PM
Greg, rgr that mate. Thanks for the info. Smile [:)]
Cheers...Snowy
Posted by Anonymous on Monday, January 17, 2005 4:15 PM
I'm just starting to paint my huge Dragon German Railway gun (Leopold) (36 inches lng!) and want to use the Tamiya acrylic gray that I have...I have just purchased (before I saw the postings here on lacquer thinner) a can of denatured alcohol...Can I use the denatured alcohol with Tamiya's acrylic as a thinner...and what proportion, please...
Posted by Anonymous on Monday, January 17, 2005 4:41 PM
I'm interested in hearing that regular lacquer thinner mixes well with Tamiya acrylics. I did not find that to be the case. However, I have found that Tamiya paints thin beautifully with Gunze Mr. Color acrylic lacquer thinner. I use this combination for all fine detailing with My Iwata HPb. Works like a charm. Had to special order the stuff, but it was worth the time and cost.
Lee
Posted by Anonymous on Tuesday, January 18, 2005 9:33 AM
Can I use denatured alcohol to thin Tamiya acrilics...and what proportion would be best.?..can't start painting until one of you lads fills me in!
Posted by Anonymous on Tuesday, January 18, 2005 2:12 PM
Billbarber, yep you can use denatured alcohol. I usually go with about 1:1 to thin Tamiya for airbrushing and go from there. I would recommend you use Tamiya's own thinner for best results though, (Which by all accounts is alcohol with some retarder or flow aid mixed in) as it seems to help with tip dry and the paint seems to level a little better. It does work out a little more expensive but if you buy one of the larger containers and use it just for thinning it will last a long, long time and I can guarantee you will have less problems.
Cheers....Snowy.
Posted by Anonymous on Tuesday, January 18, 2005 3:41 PM
Thanks, Snowy....I'll try with the denatured stuff, and if I see that it's not working well, immediately ( flow, dry tips, leveling, etc), I'll get the Tamiya thinner that you nd soem others have recommended. What do you think of the lacquer thinner everyone's talking about here? Is the odor of the lacquer too overwhelming? I wanted to try acrylic to get rid of that .
Posted by Anonymous on Tuesday, January 18, 2005 10:28 PM
I think it's great that these guys are getting the results they are and more power to em, but I think I'll just stick to my normal Tamiya thinner, it works well for me and I'm happier knowing it's at least a little friendler. Smile [:)]
Cheers...Snowy
