Acryl gloss white curing time?
    August 2004
Posted by jdavidb on Tuesday, December 28, 2004 10:09 AM
Does anyone know about how long it's gonna take for MM Acryl gloss white to cure? I put it on thick. It would not gloss up / smooth out without being thick. It is not so thick that it filled in the model's details though. It looks great. I'm wondering if the outside is curing while sealing the inside & drastically inhibiting the curing.
Posted by MikeV on Tuesday, December 28, 2004 10:52 AM
Is it in a warm enough environment to cure properly?
It should be dry in 24 hours or less being that it's acrylic.
    January 2004
Posted by MusicCity on Tuesday, December 28, 2004 12:03 PM
Yeah, they dry from the outside in and as the dry layer on the outside gets thicker the remainder takes longer to dry. That's the difference between "Dry To The Touch" and "Cured". Plastic models make things worse since no carrier vapors can escape through the plastic.
Just as a matter of possible interest, concrete cures the same way and it may take a year or longer for thick concrete to completely cure in the middle.
Acrylics dry and cure rather quickly so, as Mike said, 24 hours should be sufficient if the environment is not cold and damp.
