Rotary tool paint mixer....
Posted by Anonymous on Sunday, May 25, 2003 2:50 AM
I have finally found a way to mix paint with a dremel.
Now I know that I am not the only one who's thought of this but I have found a way it will work.
However you must do this with a dremel mini mite on low speed or a rotary tool with a compramel speed.
#1) Take a straight piece of 3" sprue(the plastic frame the part come on).
#2) Put heat to one end of the piece until it is soft.
#3)flaten out the soft plastic with a pair of pliers (or what ever is handy).
#4)Place the piece in the chuck of the tool.(you may have to adjust the collets or sand down the shaft on the piece).
#5) Last (and most important ) item.
place the mixing bit in to the paint jar or cup BEFORE you start the tool up.
If you don't do this you will be a mess.
P.S.) one more thing.
Use the lowest speed possable on your rotary tool.
(the slower the better)
I hope this works out as well for you as it did for me.
Thanks and good luck.Wink [;)]Wink [;)]Wink [;)]
Posted by midnightprowler on Sunday, May 25, 2003 7:00 AM
Cool tip, gonna have to try it. Thanks
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    January 2003
Posted by shermanfreak on Sunday, May 25, 2003 9:44 AM
Thanks for the tip James.
Posted by renarts on Sunday, May 25, 2003 10:43 AM
I tried it, it works really well and you can reconstitute older paint with it because of the thorugh mixing job it does. Thanks for the tip James.
