Tell me about it.
I learned the hard way about surface preparation after getting into large scale Resin and Vinyl figure kits. Many a kit I had to strip down to the bare material and redo after a flaw showed up later on, which can be a problem if it happens about 20hrs prior to a competition.
Also I found that in the larger scales you need to simulate/replicate the original surface texture more than on smaller scale kits.
Example:
A leather seat has a different surface texture to a dashboard, to a bonnet, to flesh, etc. A lot of those can be simulated with getting the right shade and luster of your colour.
Hang in there and if in doubt strip the kit and redo it. Often the best and quickest method to fix something.
