Primer small parts ? (pits & gears)?
Posted by Anonymous on Monday, January 17, 2005 8:42 PM
Hello,
Just wanted to know if those of you exp. modlers fine that it is worth it to prime small parts like cockpits & landing gears before painting them (using acrylics) Question [?]
Or
Just make sure that they are clean and go for it?
whether it be with a brush or Airbrush?
Thanks for the pointers Big Smile [:D]
    January 2004
Posted by MusicCity on Monday, January 17, 2005 9:22 PM
Acrylics don't adhere as well as enamel or laquer so if the parts are going to be masked I usually prime them. Likewise if I have to assemble them and do some seam cleanup I'll frequenly shoot a thin coat of primer on them just to make sure I got the seams cleaned up properly.
Posted by Anonymous on Tuesday, January 18, 2005 4:59 AM
i usually will prime my tires cos they rub against the base/floor/shelf, but for the pit and the gear i just mist on a tiny bit to help with coverage on later coats. in fact i have just painted on top of a lightly primed 1/72 X-wing cockpit. so yeah, its up to you, if you dont feel like priming today, dont bother too much. but if you want to make sure, go ahead its not futile.
