I use an artograph 1520. I consider it to be a little underpowered (rattle cans and opening the brush all the way up are both out because you get plumes of paint coming back out), but it seems to be reasonably quiet and about the right size for what I build (if your F-14 is 1/48, it will be a tight fit) . I also like the fact that it's a downdraft model, meaning the air is sucked out the bottom of the unit.
The 1520 starts off with a cardboard hood; I'd recommend spending the extra bucks for the metal hood, which has a plexiglas window in the top to allow light in. (last I heard, the 1530, a larger model, only comes with the metal hood)
The 1520 appears to be marketed under different names (and higher prices, though they typically toss in the metal hood) by Micromark and Testors, among others. I got the booth itself from Bearair, and the hood later from Madison Art supplies. I lucked out in that including shipping, buying the pieces separately was cheaper than buying them together. Of course, that was more than a year ago and prices have changed since.
Good luck.
