moisture traps..
moisture traps..
Posted by Anonymous on Tuesday, January 25, 2005 11:12 PM
is an air filter for a compressor and a moisture trap the same thing ?
Posted by MikeV on Tuesday, January 25, 2005 11:49 PM
No.
A moisture trap is either an inline device to remove water vapor or it is part of the regulator. The compressors air filter only filters out the dirt entering the compressor.
    January 2004
Posted by MusicCity on Wednesday, January 26, 2005 6:45 AM
Although there ARE combination moisture traps and particle filters. If it doesn't say anything about removing moisture or liquids then it isn't a moisture trap.
Posted by Anonymous on Wednesday, January 26, 2005 9:53 PM
ok, it looks like a moisture trap. bit it says filter, and its not for the intake of the compressor. it is an inline thing
Posted by MikeV on Wednesday, January 26, 2005 10:19 PM
Sorry Boomer, I misunderstood your question. Black Eye [B)]
Posted by Anonymous on Wednesday, January 26, 2005 10:55 PM
npWink [;)] i sitll want to know if its the same thing ... it looks like one ( glass tube like, it looks like to collect condensation) but its 30 bucks and i dont want to spend 30 bucks on it if its not what i need
Posted by MikeV on Wednesday, January 26, 2005 11:17 PM
Dixie Art has this one for $27.50
http://www.dixieart.com/Paasche_Compressors.html
Posted by Anonymous on Thursday, January 27, 2005 1:40 AM
awsome, it looked just like that one but no regulator, i'll look into that one. thanx
Posted by Anonymous on Thursday, January 27, 2005 1:45 AM
wait i forgot, my compressor is 5hp, with a 44gallon tank, and is constantly in the range of 100 psi, i have a regulator for that kind of pressure. will that one be any problems if i hook that one up by it self? or are there any cheaper without the built in regulator?
    July 2003
Posted by KJ200 on Thursday, January 27, 2005 3:25 AM
Boomer I bought the same regulator/filter last month, it's the Paasche Ra75, and IMHO is well worth the money.
I could have used a standard reg. but the graduations on the gauge would have been too great to allow accurate control at low pressures, ie below 10PSi. This one has graduations at 1PSi increments as it is designed for use with A/Bs rather than air tools which operate at far higher pressures.
I've been playing with mine over the last week or so, and it makes a huge difference to what you can achieve with an A/B.
Karl
    May 2003
Posted by qmiester on Thursday, January 27, 2005 5:03 AM
Boomer
I to have a 5 hp compressor with a 40 gal tank and built in regulator. However, I quite often use airtools with it that require a minimum of 90 psi to work. So I open the regulator to get max pressure at all times and regulate/filter the air at my paint booth. This also allows me to place the compressor as far away across the basement from my modeling room as possible. (you haven't lived until the aircompressor you keep under the desk kicks in suddenly at 2 am on a quiet Sunday. Leads to some very interesting moments - changing your underwear, cleaning up the blood from the Exacto knife, stopping the bleeding from the Exacto knife etc)
Quincy
Posted by Anonymous on Thursday, January 27, 2005 11:16 AM
Harbor freight has nice moisture traps for low prices, both inline and as an addon to the regulator.
Posted by Anonymous on Thursday, January 27, 2005 8:31 PM
LOL qmiester, i dont think i could fit my compressor under my desk ... its about the size of my desk. but i guess i'll just look around for them.
