Paint removing
Paint removing
Posted by Anonymous on Monday, January 13, 2003 12:12 PM
How do I remove paint without damaging the plastic model? Question [?]Question [?]
Posted by Anonymous on Monday, January 13, 2003 12:14 PM
Somebody recommended me to use Brake Fluid. Is that true??
Posted by djmodels1999 on Monday, January 13, 2003 12:22 PM
I think brake fluid can soften the plastic after a while, but I've never tried it. Only rumours... I use sprays of oven cleaner stuff. But as far as I know, this only works on enamels and oils.
Posted by djmodels1999 on Tuesday, January 14, 2003 4:25 AM
Also check UPNORTH's comment in the 'How to dissasemble a built Model' question in this part of the forum. Good one, Upnorth!
Posted by Anonymous on Tuesday, January 14, 2003 11:12 AM
Hey Guys,
Her eis waht I use for removing paint and it will not harm the model. I use engine degreaser. All i od is lay the model in a small plastic tub I have and let it set over night to be on the safe side. Wear some rubber gloves, to protect your hands. When removed give the model a good bath, let dry .
HTH
Posted by jcarlberg on Tuesday, January 14, 2003 11:49 AM
There was an article or two in FSM sometime back about using Bleche-Wite whitewall tire cleaner to remove chrome plating on car models. It might work on paint and decals, too. Polly S used to have a paint removing and decal removing product, but I don't know if it is still available. A strong degreaser, lye or ammonia base, would probably work, too. Castrol makes a degreaser in gallon jugs and spray bottles, but I don't know if it will affect plastic.
Posted by Anonymous on Sunday, March 9, 2003 4:54 PM
Easy Off oven cleaner and a toothbrush works well
Posted by midnightprowler on Sunday, March 9, 2003 5:03 PM
I use Simple Green to remove paint, works like a charm, and doesn't harm the plastic.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Sunday, March 9, 2003 8:48 PM
What kind of time frames are we talking about with these various materials to remove paints and glues from our projects? Have all these products readily available but am having a hard time choosing what would be the safest for myself and the plastic of the model to be using?
Posted by midnightprowler on Monday, March 10, 2003 5:28 AM
Depending onhow old and what type of paint, the Simple Green method should start removing the paint within 24 hours. It may take a day or two more, and scrubbing with a toothbrush to get it out of door panels, etc. Plus it is safe and bio friendly too. Give it a try, I think You will like it. It is also a great chrome stripper.
Lee
Posted by Anonymous on Monday, March 10, 2003 7:43 PM
i just paint over it. if needed, i use rubbing alcohol.
Posted by Anonymous on Saturday, March 15, 2003 11:41 AM
i am a new member and want to thank everyone. found the answer to my problem right away. so thanks to fsm for setting this up,
rpine
Posted by cmtaylor on Tuesday, March 18, 2003 3:48 PM
Many years ago, I had to strip some 'n' gauge rolling stock, so I put some Castrol Girling brake fluid into an empty coffee jar, dropped the bodies in, shook the jar then left it for a couple of days.
After a quick wash down, the bodies were ready for re-painting.
These days, I use a product called Modelstrip which, as far as I can gather, consists of Plaster of Paris mixes with Sodium Hydroxide into a thick paste. Application is simple; using a suitable instrument (and wearing rubber gloves!!!), cover the area to be stripped with the paste, then place it into a polythene bag for 24 hours, so that the paste doesn't dry out. After the allotted time, remove the model from the bag and wash it under a tap. Use an old toothbrush to get into the nooks and crannies. The paint should come away with the slurry. Any paint remaining can be removed by a repeat performance.
Hope this helps
Colin
Gentlemen! You can't fight in here; this is the WAR ROOM!
Posted by Anonymous on Tuesday, March 18, 2003 9:52 PM
I have used Easy Off oven cleaner on virtually all types of plastic models and have never had a problem with damaging plastic or harming details. Simply place the offending part in a plastic tupperware, coffee can, or other suitable container that has a lid, load it up with the oven cleaner, let it sit overnight and you're in fat city! Any remaining film can easily be scubbed off with an old toothbrush, so be sure to have one handy. One last point too, work in a well ventilated area as the oven cleaner fumes are somewhat noxious. Hope this helps-BT
Posted by Anonymous on Tuesday, March 18, 2003 10:26 PM
Just read an article tonight that said that brake fluid works without harming the plastic. if you try this use rubber gloves and do it out side.
Posted by Anonymous on Tuesday, March 18, 2003 10:29 PM
Here's the link:
http://www.modelwarships.com/reviews/ships/dd/dd-680/125/melvin-bu.htm
Posted by Anonymous on Sunday, March 23, 2003 12:58 AM
I did use braking fluid it works fine.
No harm done to the plastic, it even works with acrylics.
But use plastic gloves when using braking fluid, and clean the parts with hot water.
Be aware braking fluid is a chamical so don't throw it away.
Posted by BlackWolf3945 on Monday, March 24, 2003 12:36 PM
Whatever you do, DON'T do what my buddy Dan did. (Name not changed in order to further incriminate the silly)
Long time ago, in a galaxy far, far away...
Dan the man decided that he put the wrong blue on his Hasegawa 1/32 Blue Angels A-4. How to get it off? (Bright Idea Alert, Bright Idea Alert!) He took it in to work and had some of the guys sandblast it. Nuff said...
Fade to Black...
Posted by Anonymous on Monday, March 24, 2003 6:02 PM
ouch
Posted by Anonymous on Tuesday, April 1, 2003 2:34 PM
I have also used brake fluid, it worked well apart from the smell!!
I would suggest you try Chameleon Paint Stripper. I use this all the time, it comes in a gel form and can be used on most paint, obviously the time differ as to how old the paint is and what type of paint is on the model. but is does work like a charm. it can also be used to remove lettering of a pre painted body!!!
Posted by Woody on Wednesday, April 2, 2003 5:16 PM
Has anyone tried bleach? I have heard several days in Clorox will do the trick. I am curious if this will work as some of substances above create new problems {fumes, disposal, and health}
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Wednesday, April 2, 2003 7:03 PM
Even bleach has fume problems. The safest of the one talked about on this thread is the Simple Green. Use it before that others just because of it's safe factor and that it is bio-friendly.
