HELP WANTED-my airbrush, a badger 150, is spurting out water!!!
Posted by Anonymous on Friday, February 4, 2005 8:31 AM
My airbrush is spurting out water...wat should i do??? I just bought an academy 1/72scale TBF Avenger and it's paint job went to hell!Angry [:(!] Please helpDisapprove [V]
    July 2004
Posted by tho9900 on Friday, February 4, 2005 8:52 AM
as in when you are painting, drops of water are shooting out on your build? are you using a moisture trap? if not, that is the reason... you can get one at your local hardware store for about 20 dollars...
Posted by Anonymous on Friday, February 4, 2005 3:39 PM
I had an old Paasche d compressor that would spit all the time, even through the moisture trap. I ended up solving the problem by aiming a desk fan directly at the compressor. That helped to keep it cool and eliminated the water in the lines. Hope this helps!
