Xtracolor Flat - Anybody use it and whats the thinner ratio?
Posted by Anonymous on Saturday, February 5, 2005 8:33 AM
Hi everyone,
Has any one used the Xtracolor flat varnish, and what thinner ratio do you use?
I have two kinds,one in a large plastic bottle, which seems quite thick and one in a tin.
I use most Xtracolor paints (enamels), but I have a OD P-51 and Beaufighter in Ocean Grey and Dark Green to do.So want to get it right.
Any help would be appreaciated.
Posted by F105-Thud on Monday, February 7, 2005 8:01 AM
Hello,
I use Xtracolour flat varnish from the bottle or from the tin. I thin mine at a ratio of 2 parts varnish to one thinner, and spay at about 15 - 20 psi.
Only trouble with the bottle version is that it tends to go hard over the years and becomes unusable. Make sure you shake the bottle and mix it well.
