QUOTE: Originally posted by reggiethedorf
how about cellulose thinner ? this stuff melted a pair of surgical gloves [:S]
Cellulose thinner is lacquer thinner. No problem spraying it either.
The only area you do not want to get the thinner is in the trigger area as the o-ring in there is rubber and can swell and crack.
The needle bearing is PTFE (Teflon) and can handle that thinner with no problems.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
