Take a look at the topic
The Complete Future in the techniques section. It will probably do what you want.
Most military aircraft do not have a glossy finish. Most are either semi-gloss or, more commonly, flat. If you want a flat finish from Future you'll need to combine some Tamiya Flat Base with it to give it a flat finish.
Decals work much, much better over a glossy finish. What most of us do is either use gloss base paint or a coat of glossy clear before the decals. Once the decals have thoroughly cured a coat of flat clear can be added.
