I took a couple of pictures to show some differences in the 3155 Hybrid and the Anthem 155.
In this photo the needle on top is the Anthem 155 and the bottom one is the new 3155 Hybrid. Notice how much longer and sharper the taper is on the 3155.
This is a photo of the two tips in comparison.
The top one is the Anthem 155 and the botttom is the 3155 Hybrid.
The Hybrid one has a fine tip whereas the Anthem as well as the Omni's have the medium tip.
The spray regulator at the tip is from the Badger Crescendo and the head is the Anthem/360 model. The body is also an Anthem body but it's part number has a "D" on the end of it so I am not sure why. The needle tube and rocker assembly, back spring, spring adjuster and needle chuck are all from the Omni/Vega models. So yes, you could make one but you would need to buy three airbrushes to do it.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
