It sounds like you need to learn trigger control.
The Anthem was designed as a T-shirt airbrush and that is why it puts out so much paint if the trigger is pulled back very far.
Put your air pressure around 15-20 psi, push the trigger down all the way and pull back on the trigger slowly until paint just starts coming out.
Keep practicing with trigger control and you will see better results.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
