Can paint be thickened??
    September 2003
Posted by morto on Sunday, February 20, 2005 9:09 PM
I am presently working with Model Master acryl Insignia Yellow and find it to be very runny and am having difficulty getting it to adhere both via an airbrush and with regular brushing. I did NOT thin it prior to its use. Is there any way to thicken it or are there any suggestions as to how to get it to adhere better.
Thanks for any help you can give.
Mort Kisses [:X]
    September 2004
Posted by Borg R3-MC0 on Tuesday, February 22, 2005 7:49 AM
mmmh, dificult question. I believe that art stores sell thick acrilic media. this is a thick gel/cream like substance that gives your paint mode "body" cq thickens it. I don't know if it compatibel with the paint you're using. And I also don't kmow if you can airbrush it. But this is the only product I can think of that could help you.
Posted by maddafinga on Tuesday, February 22, 2005 8:32 AM
I think you'd be better off putting down a light colored primer coat then just airbrushing several thin coats of the yellow. I might take a while, but you'll get coverage after a bit, and it should end up looking good. Use a light gray or white primer underneath the yellow.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Tuesday, February 22, 2005 8:32 AM
The easiest (maybe not the fastest) would be to leave the cap off and stir it every few hours. Letting the carrier evaporate will thicken paint.
Posted by ckfredrickson on Tuesday, February 22, 2005 8:42 AM
Model Master Acryl is meant to be airbrushed straight from the bottle, and yellows and whites in general also are difficult to get good coverage with.
Maddafinga's suggestion to use a light primer and several coats is a good one, and I would add that you may want to increase the distance between your airbrush and model. This will allow the paint to dry a bit mid-air (but you don't want it so dry you get a grainy texture).
    September 2003
Posted by morto on Tuesday, February 22, 2005 1:24 PM
Thanks for the suggestions. I probably will go with the primer and then try the yellow again. Smile [:)]
