Humbrol Primer
Humbrol Primer
Posted by Anonymous on Friday, February 25, 2005 5:45 AM
Can anyone help? Is Humbrol primer a true primer or is it just a matt grey enamel packaged as a primer. Does it etch the surface? I seem to have accumulated a number of different greys and am hoping I might use them up if they are one and the same. Thanks in advanceCool [8D]
    August 2004
Posted by four-star on Friday, February 25, 2005 6:15 AM
I'm not sure if it is just matt grey or not, but in my experience, the Humbrol primer is no good, so I would not recommend using it anyway
    January 2003
Posted by leemitcheltree on Saturday, February 26, 2005 7:18 PM
Simon,
Humbrol Primer isn't in my paint box - I've never used it - I often use automotive acrylic primer.....sounds scary, but I've found that it works really very well. Etches the plastic, provides excellent "tooth" for the color coats, dried REALLY quickly, and no model paints can harm it, so you can spray ANYTHING over it.
For simple structures and builds, it's great - but it can slightly attack areas that have a lot of filler, making the filler show up. In that case, I useModel Master primers like light greys and flat white. They work really well and I've never had any problems with them.
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by Anonymous on Sunday, February 27, 2005 7:26 PM
I use Humbrol primer for all my 1/12 Tamiya f1's and think it is a great primer for that purpose. You must allow it to completely cure (i give it a week or so)....once it is cured it is practically inpenetrable. I use Duplicolor laquers over the top with excellent results. Hard finish and great to polish. The thing i like most about the Enamel primer is, if i stuff up the top coats, i can just soak the model in Oven cleaner for 24 hours and it simply dissolves the primer underneath, letting the Duplicolor "peel" off like a sheet of skin!!....much less mess and the plastic is back to it's original flawless condition Big Smile [:D]
Posted by Anonymous on Monday, February 28, 2005 2:57 PM
I used humbrol primer for a while and it was OK for my uses. Just a bit thick for a good primer. I use 50/50 Mr. Surfacer/Lacqaur thinner now with much better results.
Jeff
    May 2003
Posted by qmiester on Monday, February 28, 2005 7:30 PM
Some place years ago I got the impression that Humbrol Primer was orgionaly developed for metal figures especially lead (apparently if you painted lead figures without priming them, they would corrode under the paint, ruining the surface).
Quincy
