aussie modllers, i need ur help!!
Posted by Anonymous on Saturday, March 5, 2005 7:33 PM
hey all....
now i keep on hearing bout krylon spray cans, and how theyre used for modelling and dont damage the plastic.... now i would like a spray paint like this to use for primers, instead of using my ab....
now i wanna know if there is a similar kind o spray paint i can get here in australia?
i havent seen the krylon brand around, so is there a similar paint i can get here in oz that acts the same( doesnt damage plastic)???
thanks in advance!!!
Posted by Anonymous on Sunday, March 6, 2005 3:04 AM
I'm in Tassie and i've found the Krylon to be readily available in craft stores...Spotlight for instance. This stuff isn't cheap though!...and it goes on quite thick straight from the can. Best to decant it , thin it down and shoot through the airbrush. Personally i prefer to use the cheaper automotive primers...just as good and easier to spray imho
Posted by Anonymous on Sunday, March 6, 2005 6:38 AM
I'm in Queensland and I go to Sollys or Crazy Clarkes and get their $2.50 cans of export gray primer. Straight from the can it is OK - sometimes comes out with a slightly "lumpy" surface which can be sanded back no problems. (Might just be the operator!!) It is thin enough that it doesn;t fill in the details.
Bilko
    May 2003
Posted by qmiester on Sunday, March 6, 2005 11:05 AM
I'm not Aussie but you can get better results if you heat the can before you use it. You can use a bucket of warm water or put the can directly under a running faucet. Adjust the water temp until you can just put your hand in it and then shake the paint can, and put it in the water (leave the top on). Let it stay there for 3 to five minutes, remove the can, shake it a few times, wipe excess water off with a rag and then spray. Elevating the temperature seems to thin the paint and raise the pressure in the can. Again a word of caution, Don't put the can under the water for much longer than 5 or so minutes and especially don't put the can into water that you can't put your hand (Hot water only under the faucet and boiling water is a definate no no - you wouldn't believe the mess you've got to clean up if you do those things)
Quincy
Posted by Anonymous on Sunday, March 6, 2005 7:19 PM
dolittle: spotligt hey? i would have never thought,,,, i got some cool tools from there once, a circle cutter which comes in handy... ill check it out 2day maybe...ive though about using automotive priomers, but i was scared theyd damage the plastic...what brands do u use, ill keep an eye out 4 them....
bilko: ive used these paints, but not the proimers, just the flat paints, and i think they attacked the plastic, but i did also ue the grey primer and had good results with that, shame the primer only comes in grey :(
i found some white knight paint at bunnings and am giving that a go 2day, fingers crossed!!
Posted by Anonymous on Monday, March 7, 2005 2:25 AM
Yeah i luv Spotlight! lol. They have the white, grey and red oxide Krylon primers, but they are around $18 each here!!! I also just recently bought the circle cutter...to do a template for the "red sun" on my Honda RA273. I guess i should add to my previous post that i only use my airbrush and not spray cans, which i find spray way too thick. I use the Duplicolor automotive pressure packs, but decant out the paint and thin it at least 50:50 with lacquer thinner. I can spray it through the airbrush without killing the fine details or melting the plastic. Just remember, the acrylic lacquers etc in the pressure packs spray "hot" and will melt plastic if sprayed on too thick in one coat.
    July 2003
Posted by madmike on Monday, March 7, 2005 2:39 AM
The best primer I have found IMHO is by Tamiya. Fine White or Grey straight out of the can. Two mist coats are all is needed with no obscuration of detail or damage of the plastic. Tamiya Spraycans are lacquer based so they really provide a stable base for subsequent acrylic or enamel paint.
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    September 2004
Posted by Bandha Boy on Wednesday, March 9, 2005 7:06 AM
I'm a Tamiya White fan as well but have been trying the new primer by Alclad. It's amazingly fine & light, as you would expect it's ideal for prepping NMF's. My only gripe about it is that it's pretty transparent & hence not so good for identifying flaws for that final fix-up before laying down colour. It will become opaque but takes several (uncessary) coats before that happens. Like all Alclad products it comes pre-thinned & ready to spray.
Carl
Posted by Anonymous on Thursday, March 10, 2005 10:15 PM
yea ive seen the cans for sale at my lhs.... but theyre kinda expensive aswell........ i wish tamiya would sell them in bottle form, along with all their spray colours...(i hope someone from tamiya reads this!! ;))..... i picked up some gunze mr base white and ill give that a go... after that i might try some auto primers and c how i go with that...
    July 2003
Posted by madmike on Friday, March 11, 2005 12:00 AM
Be VERY careful with Auto Primers as a lot of them are "hot" lacquers and your model kit will suffer.
I got a large can of Tamiya for $13 last night, enough for 3-4 1:72 model kits
Citadel's skull white primer is a cheap alternative at 2-2.5 x the size of Tamiya's cans and under AU$20
cheers
