Bought First Airbrush
Posted by Anonymous on Sunday, March 6, 2005 9:20 PM
Sometime back, I asked all which airbrush to buy and received many resposes. Well, I bought a Badger 155 and a campbell compressor. Took it out, thinned some paint and it worked like a charm. Appears to be a well made piece of equipment.
Painted my first plane with it too. AMT P-40 that i had ready to go when the airbrush arrived. Uses vallejo sand and earth and mm camo gray. All in all it went pretty well and looks good (imo) for the first time out.
Problems i had...include: paint did not adhere the plastic well, orange peeled slightly (seemed to smooth out after drying) and paint pulled from the plastic when masking tape was removed...in small spots. The mm paint performed better than the vallejo....at least it seemed to...all things being equal.
I should have tried something simpler than camo for my first airbrush plane but i really was excited and wanted to see how it would do.
I touched it up with a brush, applied decals and moved on...I am pleased with it...
Thanks to reading the cleaning tips and advice here, the 155 should actually work again next time i try to use it. The choice of double action over single appears also to be the right one (although i have never used a single). The ability to control air and paint flow independently seems to be crucial.
Thanks for all the advice from those who answered my earlier posts.
    August 2004
Posted by Tankmaster7 on Sunday, March 6, 2005 9:35 PM
You should prime first befor using acrylics.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Sunday, March 6, 2005 9:42 PM
What primer, masking tape and thinner do you use when painting with acrylics?
Posted by Anonymous on Sunday, March 6, 2005 10:07 PM
I use krylon light grey, tamiya maskingtape, and 99% iso alcohol for thinner.
If you want a nice paintjob, I suggest you put down a coat of primer, sand it until it's really smooth with 2000 grit, then 2 coats of paint, more sanding, and a clearcoat and sanding. I usually do that, and it works really well.
Posted by Anonymous on Sunday, March 6, 2005 10:13 PM
I,ve never had to use primer when working with tamiya acrylics , what I do is lay down a very light coat which is like a primer and then two more coats and it works like a charm !
Posted by Anonymous on Sunday, March 6, 2005 10:50 PM
I usually use a dust coat to get paint to adhere to the recesed and raised details, then 2 coats of slightly thicker paint, followed by touch ups, all the while sanding inbetween coats
