aztec
    March 2005
aztec
Posted by blackcat on Tuesday, March 15, 2005 12:49 PM
can some 1 tell me what u need to hook up an Testors Aztec AirbrushQuestion [?]
Posted by maddafinga on Tuesday, March 15, 2005 1:00 PM
You'll need a hose, which the airbrush should have come with, and an air source. You might need an adaptor to allow the hose to fit the air supply. Any further questions you have, just keep posting them, plenty of people will be along to answer just about anything you can think of.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by ABARNE on Tuesday, March 15, 2005 2:18 PM
If you already own an Aztek, it should have come with a vinyl hose and adapters for both cans of Propel (a compressed air source best avoided), and also for the 1/4" pipe fittings that most compressors have. You'll also need to get a compressor with a regulator and moisture trap. If your AB came with a complimentary can of Propel, you can use it, but ultimately a compressor makes airbrushing a whole lot easier. Not knowing any better at the time, I went semi-high end with a Badger compressor, however a lot of members here have had good experiences with much more inexpensive compressors found at Walmart or Home Depot.
