Badger 100 for detail work?
    July 2003
Posted by KJ200 on Sunday, March 27, 2005 6:28 AM
I've been using an Omni 4000 for the last year, and have been nothing but impressed with it., however I'm finding the large colour cup a distinct disadvantage when attempting detail work such as post shading on panel lines and Luftwaffe squiggle camo in 1/72.
I was therefore thinking of getting a Badger 100 with a medium head set up. The question I have is;
'Would I be better off with the usual small colour cup on top, or would a side feed be better?'
I know that this is question of taste, but I value the opinions and experience of my fellow forum members on this sort of thing.and appreciate your thoughts.
Thanks in advance.
Karl
Posted by Anonymous on Monday, March 28, 2005 1:46 PM
It depends which 100LG you want ? I use the 100LG with the large colour cup and I its great forthat super fine weathering andf camo.
Many people would'nt suggest this but I use the fine tip on my 100LG and I find that it is excellent for doing fine work, the only thing that is the problem as far as I know is that the paint has to be a little thinner than normal but I've found that it is worth it as I'm able to create superb mottling effects on 1/72 Lufftwaffe aircraft with ease and I've had no problems with the fine tip.
As for the sidefed airbrush, to my knowledge it is similer to a gravity fed airbrush but allows for slower spraying and better vision of the model.
Btoh gravity fed an side fed are good options for doing fine detail work with a little practice, and I would suggest either!
    July 2003
Posted by KJ200 on Tuesday, March 29, 2005 8:12 AM
Stuka Thanks for that.
I wasn't actually thinking about getting the fine head set up, but considering the work that I'd be using it for, that might be an idea.
What paints do you use, acrylics or enamels?
Thanks
Karl
Posted by Anonymous on Wednesday, March 30, 2005 1:41 AM
Hey karl,
With side feed and bottom feed youll have to raise your psi a little bit, less for side feed tho. Some makers (escapes me who at this second) do make a side feed cup that the pipe stem is on the botom of the cup instead of the middle, making it into sorta a hybrid of side feed/ gravity. That might help you a bit.
    December 2003
Posted by 9x19mm on Wednesday, March 30, 2005 6:37 AM
I have a Badger 100g and must say the color cup doesnt seem to get in the way. In fact I dont really notice it at all. I have been using that AB for about 1 year now and cant say enough about it.
