Needle Lube?
Needle Lube?
Posted by woody0369 on Wednesday, April 6, 2005 9:55 PM
Alright, I've been doing a lot of reading here, and I would sure like to know what needle lube is,,,,,, where I can get some,,,,, and is there anything to lube the o-rings inside the airbrush?
Thanks a bunch!
Posted by Anonymous on Wednesday, April 6, 2005 11:58 PM
needle juice is good.
only link I have for it is www.coastairbrush.com
Only on the needle, you should never ever need to worry about the insides
    July 2004
Posted by tho9900 on Friday, April 8, 2005 6:48 AM
you can also get it a www.dixieart.com and I ditto Woodbecks comment.. it is a good thing to have... ESPECIALLY if you use acrylics but it helps a bunch with enamels too. Easier clean ups, better spraying (no paint clogging in the needle etc) are just a few of the benefits...
at about $5.00 a bottle it's worth it.. and a bottle lasts a looooong time! I've had mine almost a yr and it is still almost full.
Posted by Anonymous on Friday, April 8, 2005 4:55 PM
I"ve used vasoline for years with no problems and its cheap.
Posted by Anonymous on Sunday, April 10, 2005 1:38 PM
you can use any kinda lube as long as it doesnt effect the paint.
