Testors / Brushing paint help for an idiot (me)
Posted by Anonymous on Tuesday, April 12, 2005 7:43 PM
Sorry if this topic has been covered before, I just joined this forum today.
I've been building scale models (all aircraft) since I was a kid, and Ive never gotten the painting technique down.
I dont have an airbrush, so I hand brush all my aircraft with Testors and Model Master enamel paints.
I cant get the results to look right. The paint always looks too thick, has brush strokes, etc. (Especially when I'm painting drop tanks and wheel wells that Insignia White color. )
My technique is probably wrong. I just dip the brush right into the paint bottle, and go at it. I dont thin the paint (never even tried that before)
Is that the problem? Can you simply not get a decent looking paint job by dipping a brush right into the bottle and hand painting?
Any suggestions?
Thanks!
Posted by Anonymous on Tuesday, April 12, 2005 11:10 PM
I'm not a good brush painter either. Have you thought about spray cans? Sometimes I get good brush results from some acrylic paints but it's inconsistent. Thinner is a definite must for brush painting. Don't add the thinner to your paint. Mix some paint and some thinner in a separate container and try it out. You don't need the expensive model thinner. Get some mineral spirits from hardware store. Hope this helps you out some.
Posted by Anonymous on Tuesday, April 12, 2005 11:12 PM
Oh yeah. I forgot to say welcome to the forum. And don't go by what I say. Wait for a couple more people to post and make your own decision.
Posted by maddafinga on Tuesday, April 12, 2005 11:20 PM
I don't really brush paint either, except for small detail stuff. I always thin when I do that though. Matt Usher did an excellent article on brush painting a few months ago in FSM, see if you can find it on this site. I've heard that you should always prime if you're going to brush paint an entire model, so you might want to look into getting a rattle can of some good primer.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
    April 2005
Posted by commando on Wednesday, April 13, 2005 7:53 AM
Depending on finances, I would suggest the airbrush route. The wife bought an "Aztek" off e-bay for about $70.00, & I found an inexpensive compressor($62.00) at "Tractor Supply". I've probably spent right around $140.00 getting my equipment together. I still brush for the fine detail stuff. And sooner or later I will be up-grading the "Aztek".My 2 cents [2c]
'A government big enough to give you everything you want, is strong enough to take everything you have.' -Thomas Jefferson -
    August 2004
Posted by jdavidb on Wednesday, April 13, 2005 9:43 AM
See what you can do with some high quality brushes. The ones I get are made of red sable. I also have one made of camel hair that is extremely good. There are probably very good synthetic brushes that I just haven't tried out. So, check out the artist brush racks at art stores.
Posted by Anonymous on Wednesday, April 13, 2005 10:02 AM
Im still holding off on the airbrush route. I guess for my next model (a Grand Phoenix FJ4 Fury), I'll try thinning the Enamel paints. I'm sure there are some good FAQS on that around here....
Thanks for all the suggestions!
    July 2004
Posted by tho9900 on Wednesday, April 13, 2005 8:34 PM
yup thinning is the way.... I dont brush, I did when I was a kid but not now.. but when my dad was modeling he brushed everything... (as a lot of people did in the '60's and 70's..) thinning it was the key he said... it might take 3 or 4 coats to achieve coverage, more for light colors... but it left little or no brush marks... patience would be the key word...
for me with airbrushes so inexpensive nowadays ($59 for a Badger 155 set) there's no way I could go back to brushing... but if I did thinning to water consistency is a key...
    January 2005
Posted by jinithith2 on Wednesday, April 13, 2005 8:39 PM
I think it's in "Feature Stories" on the left column
Posted by Anonymous on Thursday, April 14, 2005 1:12 AM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]Sign - Ditto [#ditto]
its the only way to brush paint! same goes for acrylics... becareful that u dont brush the area too much (or thin the paint to much) as it will pull off the layer underneath (more so for acryls...)
Posted by Anonymous on Thursday, April 14, 2005 8:57 AM
I never use an airbrush....
I also don't thin my paints. Some of my models are displayed in the LHS, and people think I airbrush.
You can dip in the jar, just make sure you don't have a ton of paint on the brush. Going with alittle paint at a time (almost drybrushing) for the first coat or so. I usually end up with 3 coats, and the model is completely covered...no brush strokes.
As for white, it takes me an average of 10 coats of paint to get it to look right. Just make sure you only put alittle bit of paint on at a time, otherwise you'll get that *too thick* affect you were speaking about earlier.
I bought afew cheapy no-name company models to work on at first, to get used to painting. That way you don't screw up on an expensive build.
Good luck, and if you have any questions, feel free to email me.
m_24expert4life@sbcglobal.net
    September 2004
Posted by mm23t on Thursday, April 14, 2005 7:09 PM
The first thing I would suggest,is to buy a paint pallet. I have a small one that I picked up at Hobby Lobby years ago. It has 6 cups, which is more than enough. The reason for this is so you don't get dried paint on your brush from the side of the bottle. Next, some good brushes. I prefer red sable. As for thinning, a lot of the paint available now is thin enough already. You would need to use your own judgement on this. Again like everything else, practice practice, practice. Good luck.
Medals are not "Won", they are "Earned".
Mike..
    May 2003
Posted by qmiester on Thursday, April 14, 2005 7:47 PM
Welcome to the forum
As you may have noticed, thinning is one of the bigger keys in successful brush painting. Properly thinned paint will flow together behind the brush (even works on gloss paints). Whenever I open a new bottle of paint, I always add 3 to 5 drops of thinner to it before I ever put a brush in. That is usually enough for darker colors, but I thin the light colors even more and apply several coats. I try to apply the first coat with fore and aft brush strokes and let it dry. The second coat goes on with side to side direction of the brush strokes (90 degrees to first coat). Any more coats are added with the change of direction of application. Recently I've been experimenting with using laquer thinner as thinner for my lighter color - so far (knock on wood) it seems to work better than enamel thinner (only tried it with white and yellow), paint flows together behind the brush better and the colors seem to be brighter.
You're going to have to experiment and find out what works best for you. You've probably got an old kit on the shelf that you've either stolen parts out of or have gotten a version of the kit and haven't built it. Assemble the fuselage, wings and tail surfaces and use it to practice on (I do that with both brush painting and airbrushing). I keep two or three "paint hulks" around to try new techniques and pratice on.
Hope this helps a little.
Quincy
Posted by Anonymous on Tuesday, April 26, 2005 9:08 PM
Ok. A simple (hopefully) question about thinning Testors Enamel paints. Can you simply squeeze three or four drops of thinner into the paint jar, shake it up, and then start dry brushing with better results than I was getting before (with no thinner)??
Thanks!
    August 2004
Posted by jdavidb on Wednesday, April 27, 2005 2:53 AM
Yeah you can add thinner to the jar, but the key is to get it as thin as you personally want it to be. While you're using it, both mineral spirits and lacquer thinner evaporate, so that thinner is going to disappear if the jar is open while you paint from it for an hour or two. Plus, there's that tendency to dry on the inside walls of the jar which can pollute the paint with hard flakes. They usually stir back into liquid form though.
Avoid one downside... I did accidentally run across mineral spirits that was crappy at one time. It made the paint clumpy when left inside closed jars of enamel. It seems like it ate up the original enamel carrier and just left dead pigment in the jar. I don't remember the brand. Just use good brand stuff like Klean Strip.
    September 2004
Posted by Borg R3-MC0 on Wednesday, April 27, 2005 7:27 AM
I can say from experience that my painting dramaticly improved when I started thinning (and even more when I started airbrushing, but that's a different story)
I always have a cup of thinner (I use white spirit for enamels) at hand when painting.
I first dip the brush in some paint, them some thinner.
The quality of your brushes is very important but also the type of brush. Use sable for enamel and synthetic for acrilic.
If you want to cover a large area (for instance a wing), use a large(=2 to 4) flat brush. Flat brushes are ideal for that kind of work.
