Advice on Air Compressor's needed
Posted by Anonymous on Friday, April 22, 2005 11:42 PM
I am in the market to buy an airbrush, and I stumbled across this forum. I’m glad I did, there is a lot of great information from everyone here. I mainly paint Warhammer figs (28 mm), and will most likely either get a badger 155 or 360. As far as air compressors go, I did not find as much info on them here. Since I’m new to airbrushing, I’m not sure what to get. There seems to be just as much variety in price and models as there are for airbrushes. What do you get out of the high end models that you don’t out of the low end? Should I make sure the compressor is the same brand as the airbrush? Any info or advice would be much appreciated.
Posted by maddafinga on Saturday, April 23, 2005 12:41 AM
What brand your compressor is compared to your airbrush is pretty irrelavent. What kind you get will depend on what you want to do with it. If you don't mind noise, or can put it in the garage and run an air line, you might just go with a good wally world or Home Depot comressor. Those have the added benefit that you can use them for filling car tires and running air tools and whatnot. They're cheaper than hobby compressors. Hobby compressors are usually smaller, and much quieter than the other type. The one I got when I got my taxes back cost me 300 bucks, but it came with a regulator and water trap/filter, extra hoses, and an air tank. The best thing about it is that it's super quiet, you can barely hear it at all. Look at the compressors at Dixie Art's page and see what appeals to you, then go down to the Home Depot and eyeball their compressors and make a general comparison. See what would work the best for you and get that, you won't go wrong that way.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by ABARNE on Saturday, April 23, 2005 2:18 AM
I spent about 150 bucks for Badger 180 compressor. It didn't come with a moisture trap, regulator, or pressure gauge, so that was an additional purchase. It lacks an air tank, but still gives even air pressure, without any pulsating. On the downside, although it was fairly expensive, it is hardly whisper quiet and the the silly thing doesn't even have an on off switch. It's turned on/off by plugging/unplugging it. On the bright side, it thus did provide impetus to build a paint booth with a switched power outlet! Although I have no real complaints about how it works, if the thing ever blows up and needs replacement, I would probaly explore different options. If my booth is still out in the garage where noise doesn't matter too much, I would probably explore the Home Depot option, or if I have my booth inside the house, I would probaly explore a quieter (even if more expensive) option.
    November 2004
Posted by brain44 on Saturday, April 23, 2005 1:08 PM
You might want to look at an evilBay dealer known as AIRBRUSHCITY, they have a wide variety of brushes (cheapies up to Badger and Paasche) as well as a bunch of various compressors, all with the CORRECT outlet fitting. I have been pretty happy with them, since I can't really afford an Iwata yet!
Brian My 2 cents [2c]
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them." John Bernard Books (The Shootist)
    July 2004
Posted by tho9900 on Saturday, April 23, 2005 6:10 PM
maddafinga said it all - it boils down to one thing really.. noise. If you live alone or don't have a problem with noise the $60.00 one from Wal Mart will work fine. If the reverse is true then the other type would be a good bet. (and keep you out of trouble with angry, sleep deprived spouses or roomates!)
Watch the papers for a Michaels 40 or 50% off coupon, that puts their hobby compressors in the same range as the Wal Mart ones... www.badger-airbrush.com has a Thayer and Chandler refurbished compressor with a warranty for $99.00.
good luck to you!
    April 2005
Posted by commando on Sunday, April 24, 2005 6:30 PM
Try Walmart, Home Depot, Tractor Supply Co. Stay away from Hussfield-Campbell. One you can adjust airpressor on. I have a 2 gal. tank Pro Choice. Not real loud, so it won't wake the wife.My 2 cents [2c]
'A government big enough to give you everything you want, is strong enough to take everything you have.' -Thomas Jefferson -
Posted by Anonymous on Sunday, April 24, 2005 8:05 PM
I use a cheapy 5 gallon compressor that I have in the basement where I build my models. I put it in another room though, so the noise doesn't scare the bajesus out of me everytime it turns on. I tried those ones without tanks from badger and paasche and they just weren't good at providing steady or adequate pressure for me. Basically get one with a tank, regulator and water trap and you'll be OK.......
Craig
