Microscale Micro Flat Drying glossy???
Posted by Anonymous on Saturday, May 7, 2005 7:38 PM
hell all...
ive sprayed my current build woth this stuff hoping to give it a flat finish, but to my dismay, its dried glossy... not full gloss, but kind of a semi gloss..after the first coat i though it may have looked that way from the light coat, but after the 2nd one its definantly gloss! i thinned it with tamiya acrly thinner...
has this ever happened to anyone?
do u think that its the thinner?
would i b able to add some tamiya flat base t it to make it flat?
cheers!!
Posted by pingtang on Monday, May 9, 2005 8:12 AM
It could be a few things. Did you stir the bottle really well? It needs a thourough stirring to get the full flatness out of it. Tamiya thinner can give paints a more glossy appearance. Try thinning it with tap or distilled water (You could add a drop of dishwashing liquid to it to make it flow better). Don't know about the flat base, try experimenting with it.
hope this helps.
-Daniel
    July 2004
Posted by tho9900 on Monday, May 9, 2005 9:47 AM
I've had flat enamels do that to me when I thinned them just a tad too much.. I imagine the same would happen with acryls. the only other thing I could think of is what Pingy mentioned... did you stir them thoroughly? I've had some Tamiya acrylics that have done that for a reason I don't know. it was either stirring or a odd paint batch.
