orange peal effect...
Posted by Anonymous on Thursday, May 12, 2005 10:14 PM
i'm sure this has been asked before... i just did some painting with testors paint, and i got a horrible orange peal effect and looks horible ... anyway avoiding this ? thanx
    February 2016
Posted by duckman on Friday, May 13, 2005 12:33 AM
hmmmmm... well i had this happpen with there military brown
so my advice is stripped off the testors and go and buy a better quality paint (no offence intended) id suggest humbrol of testors modelmaster (for airbruch use only)
On The Bench:
Revell- 1/72 Messerschmitt Me P1099
Posted by Anonymous on Friday, May 13, 2005 1:12 AM
we need more info!!
did u spray it on?
was the paint thinned?
what airbrush?
what type of paint?
and what psi and distance did u use?
    July 2004
Posted by tho9900 on Friday, May 13, 2005 6:21 PM
if you were airbrushing you were spraying with too high of a pressure, not enough paint coming out, or too far from the model (or a combination of any of those). Try adjusting one of those at a time and see how it comes out. What pressure were you using? typically unless I am spraying future I don't go above 20-25psi, you want sufficient paint coming out of the airbrush to sort of form an oval of paint when it hits the surface, not a dry grainy like texture, and you want to be within 3"-4" or so from the model when you do an all over coat.
If you were using a can of spray paint, move the can a little closer, within 6" to 8" (it usually recommends a distance on the side of the can) and move in a steady motion (don't go too slow or the paint will build up too thick)
You can sand the orange peal off with progressively finer grades of sandpaper and shoot it again, or use something like easyoff oven cleaner or Castrol Super Clean to soak the paint off. (if you go this route remember, the paint on the inside of the model will come off too and will be very hard to put back on!)
Posted by Anonymous on Friday, May 13, 2005 11:00 PM
yes i sprayed it on...
yes the paint was thinned
i use a badger 200
and i said testors...
i use 20 psi, and i'm not sure what the distance was ... i guess to far away, i was afraid of getting runns
i also did 3 coats , so i think it got plenty of coverage
