QUOTE: I have a water catcher before AND after the tank, and only the first one actually gathers any moisture, and not even much at that. |
Having a moisture trap between the compressor motor and the tank sounds like a good idea, but before anyone tries is make CERTAIN that the moisture trap is rated for a pressure greater than the maximum pressure of the tank. Most items like that are rated for somewhere around 90 psi. Many general-purpose compressors will easily exceed that. Mine pressurizes the tank to 140 psi.
QUOTE: To date I have not had any water in the tank, but I do live in the desert, so I guess I dont count
Well, not everyone can live in the middle of an Oz desert, Sean
I frequently wish I did though, it must be nice.
