need website or address
    November 2003
Posted by GA.modelmaker on Wednesday, May 18, 2005 5:15 PM
hey guys,i need the pasche website or thier street address, i have i belive a pasche h airbrush and it will not spray. it is clean i have took the parts that need to be cleaned and put the back the way they go but it will not spray at all. thanks robBig Smile [:D]
Posted by Anonymous on Wednesday, May 18, 2005 5:20 PM
you have the "H" model single action external mix. http://www.paascheairbrush.com/
have you used this brush before? are you familiar with it? or was it "passed" on to you?
    November 2003
Posted by GA.modelmaker on Wednesday, May 18, 2005 5:41 PM
yep i have used it before and i am the only owner of this airbrush thanks rob.Big Smile [:D]Big Smile [:D]
    January 2004
Posted by knight667 on Wednesday, May 18, 2005 5:42 PM
I have this AB and it works great for me; it's a little picky about how thin paint is, but other than that, it's great.
What problems are you having (other than it not spraying)? What's your setup like?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    November 2003
Posted by GA.modelmaker on Wednesday, May 18, 2005 6:19 PM
if your refering to the compresser. i have a blue mini by testors its plenty strong and its set at 15 psi, so i know its strong enough. it wont even spray future. as for the paint i am using model master enamels and is thined plenty engough togo thru the pasche but it will still not spray at all.Big Smile [:D]Big Smile [:D]thanks rob
Posted by Anonymous on Thursday, May 19, 2005 9:26 AM
The Paasche's typically require a much higher psi ( as noted on their instruction sheets ) to operate than the Badgers. Try cranking the psi up to at least 20 psi or more if possible to see if you can get it to spray. If you have a spare can of propellant around, you can use it at the full open position to test your brush. Hope this helps.
