I've done it this time folks !! ...
Posted by ipms40049 on Thursday, May 19, 2005 10:10 PM
.... totally flubbed up my paint job on my Corsair. ITs completely dry, now what can I use to take about two layers of paint off?
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by Anonymous on Thursday, May 19, 2005 10:28 PM
what kind of paint do u need to strip? these will work...
brake fluid, Castrol super clean, easy off oven cleaner, straight amonia (if its acryl)
be careful when using them, coz theyre pretty toxic!!
Posted by Anonymous on Friday, May 20, 2005 7:54 PM
I've used alot of stuff to take off paint from my very bad work sometimes Big Smile [:D] I prefer using ELO. It cost's more but works very well for me.
Posted by MikeV on Friday, May 20, 2005 8:43 PM
Castrol Super Clean is the best. Wink [;)]
    August 2004
Posted by Tankmaster7 on Friday, May 20, 2005 8:55 PM
I have a question for you guys. If there is a need to strip the paint, how do you get it from leaking into the cockpit, where you want to keep the paint job?
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Friday, May 20, 2005 10:28 PM
I use simple green.
    January 2003
Posted by plasticmod992 on Saturday, May 21, 2005 11:35 PM
I was commisioned to refurbish a friends model some time ago and had to strip the very ugly paint job. I used Polly S, ELO and ran into the same delema regarding the canopy. What I ended up doing was to mask the canopy with tape and apply the ELO on the major parts. I then came back to the canopy area using sanding pads to remove any left-over dried paint. This way I had better control and I could be more precise in removing old paint from these critical areas. If I accidentally blimished the clear canopy, I simply went over it with a Tri-pad polishing wand, availble from Squadron. The model was then ready to be re-painted and finished.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
