thinner question
thinner question
Posted by Anonymous on Saturday, June 21, 2003 3:55 PM
I need to buy thinner for my tamiya acrylic paints and testor and Model Master enamel paints, and the i see that each make their own thinner. However, the tamiya thinner says to use for acrylics and the testors thinner says to use for enamels. My question is, do i really need both or is their one that will do the job for both??? Is there a better brand that can handle both or one that is less costly???? thank you
Posted by Anonymous on Saturday, June 21, 2003 4:20 PM
i use Isopropanal alchohol for the tamiya you can get it from chemists
ive herd about peaple useing the blue screen wash for tamiya paints with no change of colour
Posted by Moses on Saturday, June 21, 2003 4:39 PM
jksprau, you can use 90% or 70% Isopropyl Alchohol to thin Tamiya Acrylics, but I highly recommend you use Tamiys's X-22A Thinner. I say this because Isopropyl Alchohol dries a bit quicker then Tamiya's thinner and it sometimes will cause a grainy effect to your base coat.
You can not thin Enamel paint with Isopropyl Alchohol or Tamiya's Thinner. If you buy Humbrol Enamels, you can thin it with their thinner or with Mineral Spirits, Model Masters also has their own airbrush thinner, which is also Mineral Spirits.
Again do not use Acrylic thinner or Isoprpyl Alchohol with Enamels.
Rob
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Anonymous on Saturday, June 21, 2003 6:19 PM
I use 90% alchohol for Tamiya acrylics and I use the Model master acrylic thinner for Model Master acryls... The acryls are thicker and tend to clog the tip if I use alchohol...
    July 2013
Posted by modelmaker66 on Monday, February 22, 2016 2:55 PM
always use the reccommended thinner for best results.
    February 2010
Posted by EBergerud on Sunday, February 28, 2016 2:57 AM
Tamiya paint has one and only one thinner if you want top results, especially for any kind of low pressure, multi coat detail or camo work. Acrylic is a very tricky term - practically Tamiya is a lacquer paint. (Look on the label: say flammable? toxic? if so, it's lacquer.) Hence you want to use Tamiya's own brand of lacquer thinner (Gunze Sanyo paints are the same and Gunze lacquer thinner will also work fine). I think people that use A-20 or any ISP brew are just very good with an airbrush and can adjust the flow by nature. Lacquer thinner will give you a smoother coat of any kind. The stuff is cheap and will last a long time. About eight years or so back when armor gurus Adam Wilder and Mig Jimenez began making this argument, Tamiya A-20 users blew gaskets. Now the argument is over. Lacquer thinner it is. But note: do not use hardware store lacquer thinner on plastic - it's much stronger and can damage styrene. I use a "green" hardware store lacquer for cleaning airbrushes. But not on models.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
