What am I doing wrong?
Posted by Anonymous on Saturday, June 21, 2003 6:43 PM
I am using acrylic paint and approx 20 lps pressure and am getting abead like coating on the surface I am painting. Is the paint not thinned enough or pressure too much or?
Posted by Anonymous on Saturday, June 21, 2003 7:46 PM
Is the bead...a bead of paint from blast hitting model? Any chance you are too close or throwing too much paint for that distance?
dunno,trying to help.....not an experienced airbrusher
Posted by RonUSMC on Saturday, June 21, 2003 8:02 PM
Too much paint or too thick..
Back up or move faster.
Your best bet is to back up.. .do several thin coats.
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
Posted by Anonymous on Sunday, June 22, 2003 1:28 PM
Thanks Gang I think I was doing both, too close and paint to thick. Will try again
Posted by dubix88 on Monday, June 23, 2003 4:04 PM
HEY,
This may not help much but are you using a primer? If not, do it. I f you do sorry i couldn't help.
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Monday, June 23, 2003 4:47 PM
This may seem simple but, did you clean your model with soap and water before painting? sometimes the oils from your fingers will build up on the surface and the paint will not stick. Also the mold release agents on resin cause this.
Posted by MikeV on Monday, June 23, 2003 10:49 PM
If your paint is too thick then you should see a pebble looking finish on the model almost like there was sand in the paint.
Is that what you are describing?
