RE: My aircompressor again..
Posted by ipms40049 on Friday, June 3, 2005 7:00 AM
I left my hobby room windows open yesterday, the weather outside was raining and about 75 degress, this morning its foggy, would that have something to do with water getting in my line?
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by dtraskos on Friday, June 3, 2005 8:25 AM
It has everything to do with it. The compressor is just compressing the same air you are breathing. If there is high humidity there is a lot of moisture in the air that you can`t see, except in the case of fog. When you take a volume of atmospheric air and compress it into a much smaller volume the invisible moisture in the air turns into visible moisture which is the water you see. If you lived in Arizona, where the humidity is so low, you might not need a moisture trap.
Posted by dtraskos on Friday, June 3, 2005 8:26 AM
Posted by ipms40049 on Friday, June 3, 2005 8:28 AM
Thanks, yeah I live here in Mississippi and we have High humidity all the time.
thanks again, Ive switched over to my other compressor until I can get a better moisture trap for my line for the other one.
Posted by dtraskos on Friday, June 3, 2005 8:31 AM
Oh well !!I see my reply was sent twice. That`s what is called pilot error.
Dave
Posted by ipms40049 on Friday, June 3, 2005 8:35 AM
Dave
NO, thats whats called making sure I read it !!! LOL
    May 2003
Posted by qmiester on Saturday, June 4, 2005 7:27 PM
Actually it's operator headspacing and timing LOL
Quincy
Posted by ipms40049 on Saturday, June 4, 2005 7:29 PM
LOL
    January 2005
Posted by STUG61 on Saturday, June 4, 2005 10:26 PM
Pat, I live up here in Michigan and this time of year the humidity is killer, (Great Lake State). I finally had to put an in line filter along with the filter in my regulator. That was after trying what I thought was a better Reg. filter. Since I put in both no probs.
Smile! It makes people nervous!! Andy
    May 2003
Posted by qmiester on Sunday, June 5, 2005 8:05 AM
Pat,
There are very few of us who use an airbrush that haven't had this problem at one time or another. When I first had the problem, I installed an in line filter which I got from the local auto supply store. I then found a rather large wall mounted water trap/air regulator (like a professional car painter uses) at Harbor Freight for about 30 bucks. I replaced the air pressure guage (it worked fine but only gave the pressure in 10 lb increments, not the 1 lb increments I prefer) and replaced most of the pipe fittings in it (I have yet to see a pipe fitting that is made in the Far East that actually seals). The seperator will hold about a quart of water before it starts spitting water, but I've found that if I drain it about every two weeks, there are no problems.
Quincy
    April 2004
Posted by crockett on Sunday, June 5, 2005 9:20 AM
I've found a slightly more expensive alternative. Having the moisture problem even after the in line traps were installed, (I'm in my basement), I just went and bought a dehumidifier. Works great, no more water in the lines but a slightly higher electric bill!
Steve
Posted by Anonymous on Tuesday, June 7, 2005 3:13 PM
Steve,
does that dehumid the whole basement or just the area around the compressor???
    April 2004
Posted by crockett on Tuesday, June 7, 2005 4:37 PM
It sucks the whole enchilada dry as Cinema 1 popcorn buddy!
