cheap compressor?
cheap compressor?
Posted by Anonymous on Friday, June 3, 2005 3:20 PM
i bought my testors a470 at hobby lobby, and bought testors little blue air compressor with it. it seems to work fine but you cant adjust it. i was wondering if anyone knows how much pressure it makes? not sure what its called, but its small and housed in clear blue plastic.
Posted by maddafinga on Friday, June 3, 2005 4:29 PM
You just need to get a regulator at Wal Mart or some other such place. Then you can adjust the pressure. I think they put out about 30-35 pounds, but I'm not positive about that. Spend 25 bucks or so and get a regulator, it'll be well worth it I promise.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
    August 2004
Posted by Tankmaster7 on Friday, June 3, 2005 5:30 PM
That compressor is the one I have. It puts out 20 PSI tops. I am looking into getting a new one, and you should too.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    July 2004
Posted by tho9900 on Friday, June 3, 2005 6:39 PM
a regulator will help you get the pressures controlled but Tanky is right, the mini blue can't put out a lot of pressure. Eventually you might want to upgrade to a commercial style compressor at the least. (about $60.00 at Wal Mart) which can put out more pressure than you would know what to do with...
But for now it will help you a lot with a regulator attached!!!
    April 2004
Posted by crockett on Friday, June 3, 2005 9:08 PM
I gave up on the little blue compressor months ago, it's a real weakling.
    January 2003
Posted by yardbird78 on Friday, June 3, 2005 9:46 PM
Buy a stadard compressor with a 1 1/2 to 2 gallon tank. They usually come with a pressure guage and regulator. All you have to add is a couple of dollars for fittings and then a moisture trap. The moisture traps/filters are a little pricey, but absolutey essential to spraying models.
Darwin, O.F. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
Posted by Anonymous on Tuesday, June 14, 2005 11:04 AM
I just bought a Craftsman 1 1/2 gallon aircompressor with 150 psi from Sears this weekend: http://www.sears.com/sr/javasr/product.do?vertical=TOOL&pid=00915239000&bidsite=&BV_UseBVCookie=Yes
Has anyone out there had experience using this one?
Thanks,
Brian
