Removing paint and "chrome" plating
Posted by ga.retread on Saturday, June 4, 2005 11:46 PM
I know I've seen it mentioned in a couple of different posts that you can use automobile brake fluid to remove paint from parts without harming the plastic. However, will brake fluid also remove the chrome platng from parts? If not, is there anything else that will?
"Shoot low boys, they're riding Shetland Ponies!" - Lewis Grizzard, revered Southern humorist
Posted by Anonymous on Sunday, June 5, 2005 1:49 AM
i think it may, but i aint sure mate,,, if u got some laying about, give it a go, u ainyt got nothing to loose
i know that straight house hold bleach will remove chrome plating, but ive never tried this....
u also could try some other paint strippers, CSC, easy off oven remover or amonia
    January 2003
Posted by yardbird78 on Tuesday, June 7, 2005 2:13 PM
The easiest and safest way to remove the chrome plating on plastic parts is to soak them in Westley's Bleach White, the stuff intended to clean white side wall tires. Is available anyplace you buy automotive accessories, such as cleaners, wax, etc. It takes one or two hours. Wash with soap and warm water when done.
I use DOT-3 brake fluid to remove old paint and decals. It is a petroleum product,so you should use some ventilation and probably rubber gloves when using this stuff. Soak for 1/2 hour to an hour, then scrub LIGHTLY with a cotton swab or old toothbrush. Wash thoroughly with soap and warm water when done.
Darwin, O.F. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
Posted by ga.retread on Saturday, June 11, 2005 7:43 PM
Thanks for the "comebacks".
Yeah, there are several car parts places nearby, so I'll look for some of this "Bleach White". I'm also going to experiment whth the oven cleaner,too.
