A simple Alclad question
    March 2005
Posted by Aviator on Monday, June 6, 2005 10:24 PM
I know that the MM metalizers can be buffed (well, most of them), but most people seem to be leaning towards Alclad II. What I was wondering is, do you have to buff Alclad to make it shiny or do you just spray it on and let it dry?
    February 2005
Posted by MA Cooke on Monday, June 6, 2005 10:48 PM
Go see Swanny's webiste, he has a tutorial on Alclad II (by the way, you don't have to buff it, but you can).
http://www.swannysmodels.com/Alclad.html
Swanny should have a bunch of sticky posts.
On Bench: AM P-51B, Tamiya 1/48 F4U-1A On Deck: Hasegawa F-14's (too many); Tamiya P-47D; Academy P-47N;
    March 2005
Posted by Aviator on Monday, June 6, 2005 11:00 PM
OK, thanksBlush [:I]
    January 2004
Posted by MusicCity on Tuesday, June 7, 2005 7:03 AM
Spray it on and let it dry. Some of the colors require a black primer beneath though. Swanny's site goes into a lot of detail as does the Alclad site at http://www.alclad2.com/alclad-home.html
    March 2005
Posted by Aviator on Tuesday, June 7, 2005 12:13 PM
I went to the site and I see that it says
PRE-THINNED FOR AIRBRUSH APPLICATION & DRIES IN TEN MINUTES
NO SEALER REQUIRED
DOES NOT LIFT WHEN MASKED
As for the MM Metalizer, it requires sealer and it's not a good idea to mask it either. Alclad is sounding better and better. Thanks for your help.Big Smile [:D]
    May 2004
Posted by KINGTHAD on Tuesday, June 7, 2005 12:20 PM
Give it a try it is worth the $$$$
Thad
    January 2004
Posted by MusicCity on Tuesday, June 7, 2005 1:11 PM
NO SEALER REQUIRED
Yeah, well that's about 99% true. Some of the colors lift slightly. I've only used Stainless Steel, Chrome, and Polished Aluminum. The stainless steel is solid as a rock. When I mask the other two I usually see a little bit of paint on the tape when I remove it (always, ALWAYS, Tamiya tape). A coat of Future over it will usually prevent that from happening and usually deepens the gloss.
I've only used MM Metallizers from a rattle can. I just really hate airbrushing laquer in the basement and with rattle cans I can take the parts outside and spray them. Alclad is, in my opinion, just plain better.
    August 2004
Posted by Tankmaster7 on Thursday, June 9, 2005 8:11 PM
Yeah. However, MM metalizers LOOK just as good. They just come of real easy.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
