aztec airbrush
aztec airbrush
Posted by Anonymous on Saturday, June 11, 2005 9:11 AM
I think i missexplained my problem that i have with my airbrush,so i will try to put the right words on the right things.(that what happen when english is not your first language)When i use the gravity cup feeder in single action mode the mode flow out the cup without i press the trigger the paint flow out in big drops it is like they are i leak in the nozzle or the airbrush. I try new nozzles but the problem appear again.This problem doesnt appear when i use the double-action mode. I follow the instruction very carefully , i thin my paint correctly and i clean my airbrush very carefully afer each use and i dont diasassemble the paint nozzle.Boohoo [BH]
Posted by ABARNE on Saturday, June 11, 2005 3:53 PM
QUOTE: Originally posted by André Delcambre
...right words on the right things.(that what happen when english is not your first language)
Your English beats my French, so I won't criticize your use of English. God knows when I'm able to catch a Canadiens telecast from Montreal, I have no idea what the French announcers are saying Big Smile [:D]
About the Aztek, it sounds as though my post on your original thread is probably more or less correct. I suspect that if you use the Aztek in a single action configuation, you'll need to use the siphon bottle rather than the gravity feed color cup.
Andy
Posted by Anonymous on Monday, August 8, 2005 7:26 AM
Hello! Is it an Aztek? If so, the nozzle is too loose. Azteks needs to be tightened very exact. Wich isnt mentiond, only "not too thight". Which is when it breaks, so just untill right there somewher is the place to get the nozzle... Good luck, hope i helped since im just guessing, but it sounds like what ive just been throu with my own aztek.
Posted by Anonymous on Monday, August 8, 2005 9:29 AM
Sounds like you aren't thinning the paint enough. Or the airbrush or the nozzles may be clogged.
