Help: Handbrushing with Tamiya Acrylics
    July 2004
Posted by eddiemac0 on Thursday, June 16, 2005 8:59 PM
Hi everyone,
I'm having a lot of trouble getting even and consistant coverage with Tamiya acrylics. Either I add too much paint and it dries in bulges, or its too thin and watey and streaks when it dries. I did some building and painting (all by hand) last year and don't remember having nearly as much trouble.
If anyone has any ideas, or threads to reference, I'd be very appreciative.
Thanks!
Posted by Anonymous on Thursday, June 16, 2005 11:54 PM
I gave up painting anything but a tierod with a brush; I do detail work only; small small areas that arent big enough to be bumpy.
everything else is airbrushed, EVERYTHING.
my modeling has never looked better.
blacks and silvers are an exception cause they cover well; the metallic silvers, reds, yellows, ect; airbrush them suckers. save a world of greif.
Posted by Anonymous on Friday, June 17, 2005 2:42 AM
using a primer (tamiya surface primer of gunze mr base white r 2 exapm;es) will help the acrly adhere and cover better
also, thin ur paints (when brush painting i add a few drops of tamiya thinner, not much at all) and it will help them flow, and apply the paint for thin coats.
also, have a browse thru this forum 'Painting and airbrushing', and u will find some posts of ppl who have had the same prob
hope this helps
oh, and also, Sign - Ditto [#ditto]Sign - Ditto [#ditto]Sign - Ditto [#ditto]
    January 2004
Posted by MusicCity on Friday, June 17, 2005 6:40 AM
I can't handbrush anything without making a mess, but that certainly doesn't mean much. I've seen too many immaculate paint jobs done with nothing but a brush.
Two things I do know about handbrushing:
1) You absolutely have to get the paint so it will flow properly or you get uneven coverage.
2) When using acrylics you absolutely have to slow down the drying time or you'll get ridges and rough coverage. The paint must have time to level out before it starts to dry, and acrylics don't give themselves enough time.
With Tamiya acrylics the best way to dd both of those things is to use their brand of primer. It thins the paint so it can flow and it also has some retarder in it to slow down the drying time. I don't know how their primer works with other brands of acrylic, but you can thin them with various substances. Acrylic retarder is available at most art supply stores and a drop or two will dramatically slow down the drying time.
