Primer and topcoat
Primer and topcoat
Posted by Anonymous on Thursday, June 26, 2003 9:01 PM
Do you guys recommend priming and what topcoat do you suggest?
    January 2003
Posted by leemitcheltree on Sunday, June 29, 2003 9:58 PM
Umax,
I almost always prime before I topcoat.
The type of paint I use depends on the subject and the material I'm painting onto.............
I like to use automotive acrylics for cars because It can be polished to within an inch of it's life for that "glassy, wet" look.
I always use gray primer for black topcoat, and white primer for other colors - especially gloss white, yellow, reds or blues.
For armour, I often use a primer color that fairly closely matches the topcoat color - and sometimes I just paint the bare plastic with the topcoat as armour sees hard use and doesn't need to be "pretty" to be effective.
For aircraft, I do a lot of airliners, 1/144 scale, and as they never really have that much in the way of detail, I usually make them into the "travel agent" style model with blacked out windows and a glossy paint scheme - then I usually use a flat white primer, then hit it with Future for a gloss, then decal, then Future again.
There are about a thousand different techniques that people will use that differ from mine, but these ways work for me.
Cheers,
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by midnightprowler on Monday, June 30, 2003 9:20 AM
mostly build car models, and always prime. I use Dupli-color primer, and Testors clear enamel for the clearcoat when needed. Hope this helps.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
