QUOTE: Originally posted by Tankmaster7
I would reccomend an aztek if you dont mind cleaning the thing for a good half hour after you are done spraying.
Just for the record...
I use MM enamels for nearly everything and Future is the only non-enamel item I shoot through my Aztec. I've owned it for two years and I'm still using the same two tips (general purpose and heavy) that came with the brush. Here's my cleaning method:
1) Finish shooting paint (zero time)
2) Remove paint cup and attach paint cup with pure thinner (30 seconds, maybe)
3) Shoot until clear (about 30 seconds)
4) Remove thinner paint cup and shoot until only air comes out (about 15 seconds)
5) Remove tip and drop in a MM enamel jar of thinner (about 5 seconds)
6) Run a pipe cleaner into the hole where the paint jar attaches (about 10 seconds)
7) The airbrush is DONE (total time: about 1.5 minutes)
8) Finish cleaning up the paint cup and the thinner cup (about 5 minutes)
I've used this same procedure for 2 years - probably 40 or 50 times - and fail to understand how people claim this is time-consuming.
[Off my soap box...]
