- Member since
Posted by ipms40049
on Monday, July 4, 2005 3:23 AM
QUOTE: Originally posted by TJ ace
I've started spraying the bottom of my F4U and I'm getting some real wet spots when I spray that streak with the airflow. I've used the AB before with Zinc Chromate and a Light Grey with no similar problem. I'm using MM Acrylics Flat White with a little less than a 1:1 ratio of thinner. The wet spots appear to be unmixed thinner. Could this be? I don't have a lot of little mixing jars lying around, I usually mix in the color cup with a toothpik. Maybe I'm NOT getting it mixed well enough. Any thoughts?
i USE floquil Refeer white, thats the best white to use.
Pat Hensley
Booneville, Ms
"Thank you for being here and playing nice"...please do not drag sand outside the box !
CURRENT BUILD(s)
Revell 1/72 U Boat VII C
Tamiya Willys Jeep - for 2010 Nats
Bronco's Staghound -for 2010 Nats
Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
